Finally Got My Truck Home
I'm not sure what section to post this in since I have a few different questions. a little background on my truck it is a 2004 F150 Lariat with a 5.4 3 Valve and only 39,000 miles. My truck sat in my mom's backyard from 2006 until 2 weeks ago. It was my step father's truck and was left to me when he passed. In 2009 I built the truck in memory of him, but it continued to sit in storage because I was in the military. It saw an occasional road trip when I came home. The truck has a 3/5 drop, afe intake, bbk throttle body, magnaflow high flow cats w/custom y pipe and 3 in exhaust dumped before the axle, and a superchip flashpaq. I went to pick up the truck and mice and rabbits had a field with my electrical. I had to replace the main electronic harness for the trans because it was chewed through. Now on to my questions. I ran a scanner on my truck due to check engine light being on. I know I have to replace the cht sensor and harness and knock sensors because I can see the harnesses are chewed through. Do I need to pull the alternator and coolant crossover to get the manifold out? I also have a code for the motion charge plates. What exactly do these do? Should I plan on replacing the spark plugs while the intake is off and apart? would it benefit me to open the manifold to match the throttle body? also should I look into doing a custom tune instead of the canned tune?
