1994 F-150 4x4,,run's 15 mins then shuts off.
Hi,have a 94 ford ,I changed the battery in it,then the air bag light started to flash,after that happened it will run 15 min's and then it startsto back fire and spuder and then the engine dies.wait a few nins and it starts right up again for another 15 mins and dies again,thanks for any advise you can give me what's going on with it.
The ignition module is mounted on the distributor on the front where it heats up and suffers from voltage breakdown from the hot air coming through the radiator or at least it was on the 86 302 I used to have. i've heard of people buying a cold drink and pouring it on the module to cool it off so it will work. If you are currently in the frozen north then this may not be it. Maybe the 94 is different. I don't remember looking for that on the 94 302 I had.
Thank's for the advise, the wire's are getting fire to them,and I live in florida.i'll check the mod.. when it warm's up.http://images.ibsrv.net/ibsrv/res/sr...ies/coffee.gif
did they really move the ignition distibuter off the flywheel? And for the very same reason, it started in 1992 (fendleyweely.
Hey masseyman, me again, did that really happens in the first few minutes? i'll have to go that a byall. And i am getting spark through them spark plug wires. and there all cranking good. and i already tested it i am not loing spark a tall. just thought you needed to know for sure.
