COP, good or bad test
Need to find out how you can tell if your COP is good or bad. I have a 98, 5.4 that has a miss under mild acceleration, but idle is perfect. If I am running along at anytime, and I accelerate at all, a miss and shake takes place. I have removed all of the coils, and did an OHM check, they are all in spec. .5 across the terminals and 5.5 from one of the terminals to the plug spring in the boot. Approx. Under drag acceleration, I do not feel a miss, but it doesn't pull like it should. Like maybe all 8 are not firing.
One thing I did was remove the elec connection to the COP, start the engine, and rev it up from idle. I can tell that a plug is not firing. I did this to all 8 with the same results. Even with all COP's connected, and I rev it up, it does not rev smooth. So I am thinking that at idle the COP is fine, but rev the eng and the COP breaks down.
All new Motorcraft plugs.
What can be done to test the coils? I really don't want to buy a whole new set of coils, if there is another reason for the miss.
