searching for a performance radiator
hey guys, i have been doing some research and i cant find anyplace that sells a drop in performance radiator for a 06 5.4. Mine is cracked and i need an upgrade and when i mean performance, i mean a 3-4 core all aluminum thick radiator. I was thinking about buying this one: http://www.ebay.com/itm/140881980454...84.m1423.l2649
but its just a little shorter then the original stock f150
you guys have any suggestions?
my truck is set up for racing in the NM dessert so i will need something more then the oem one. thanks for your input
These are all meant for the 06 F150. Might also try searching for a 3 row. You will have to put back in that it is for a 2006 Ford F150. It unfortunately did not keep that.
http://www.summitracing.com/search?S...eyword=4%20row
