600+rwhp!!!!???
600+rwhp!!!!???
I'll Keep this short and too the point. I've got a 01 HD F150 with bolts-on's as of right now. I have bought the following list (Trust me I know how many times you've heard this line but I honest to god have)
IN MY CLOSET:
38cc Trick Flow Track Heat Heads Fully Dressed
226/230 550. Lift Comp Cams
DSS Racing .40 Forged Pistons (Should Yield 10.5 to 1 with 38cc heads)
Manley I-Beam Rods with Arp Studs
MMR Forged Crank
Zex F150 50-135 HP bolt on kit
ALREADY INSTALLED:
SCT Livewire TSX 4015 (No Custom Tunes Yet)
BBK Throttle Body
BBK Underdrive Pulleys
Flex-A-Lite E Fans Kit
K&N Intake System
No Cats With Borla Exhaust.
My Question Is 600 RWHP Possible with this motor?
Reason I ask, I'm a Sales Manager at a Independent Junkyard and we just got in a lightning with 76k on it rear ended. Would a supercharged version stand better chances then nitrous version? Keep in mind I've already got the parts for the N/A motor
IN MY CLOSET:
MMR Forged Crank
ALREADY INSTALLED:
BBK Throttle Body
K&N Intake System
600 wheel? Not on a stock bottom end, not even a stock Lightning bottom end is going to take that. At least not for long.
Just looking at the engine in your first post I'd say that one should manage it though unless I'm missing something.
No reason you couldn't run 10.5:1 with good tuning and reasonable boost levels.
-Steve
-Steve
I've got the fuel system and Maf covered, the transmission is also built stock 9.75 with Moser Axle Shafts so I see no weak point in my system, I do however Believe with a wet system I wouldn't need massive injectors!? Am I wrong on that one?
