Fuel Filter
My friend just had this happen in his motor home. It was frustrating to diagnos because it ran fine with more fuel in the tank. Even with only a little bit of fuel in the tank, once the pump cooled down, it worked for a while. I don't know that running the tank low caused the problem, but his motor home has a relatively small tank and he'd just done a cross country trip where he was stretching each tank out to the max. I would think that any fuel pump will wear out eventually.
jonboy,
You can run your fuel pump below a 1/4 of a tank in your F-150 and not worry..I did it all of the time in my 98 F-150 without a single problem. Be very careful NOT to run it empty...because this can easily ruin your pump or clog your filter. In fact, you have to go below a 1/4 of a tank before the low fuel light will come on.
Some other newer vehicles just might have this restriction. There are no published restrictions for the F-150s to date about this that I have found.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, cabin filtration system, Bugflector II
