05-09-2012, 06:30 PM
2007 Ford F-150
Vehicle: 2007 Ford F150
Running 5.13 gears with 35" tires
I have an 07 4.6L with an 8.8 rear end. Is this going to be a problem? Found an amazing deal on some 513's and seriously considering this. Any input would be greatly appreciated. thanks.
05-09-2012, 07:25 PM
I say go for it. I had 4.56s with my 35s and 4.6L and it still struggled a bit. You're speedo will be 20% or more off depending on what gears you started. Mine was about 10% if I remember correct. The 4.88 gears are probably about perfect, but the 4.6L needs all the help it can get so 5.13 should do nicely.
I would recommend a tuner for speed calibration and added power. Did you get the tires yet? Pay attention to the weight. Every pound should is important when deciding on new tires. (most should be LT rated) My toyos were 80 lbs, yet some 35" tire are only 65 lbs. For 4 tires that is a weight difference of 60 lbs of rotational mass, which if I understand correctly, has the same toll as 600 lbs of normal weight. Dang!, Think about it!  Good luck on the gears.
05-09-2012, 07:49 PM
2007 Ford F-150
Alriiiiiiiiiiiiight  thats what i wanted to hear. A friend of a friend has them all boxed up not even taken out of the packaging with a minor install kit and he'll let me have it for $150! So i'm definitely going to jump on this one. I already have some tires too but they're some cheapies.. BFG TKR CORR race tires that i picked up new for only 300 bucks. I know they're not DOT approved, will be loud as sh*t, and will probably wear out pretty quick but for that deal and the look of the tire i couldnt pass it up. I also have a gryphon programmer already put in so all i need to do is figure out how to customize it to these new tires and gears, which i'll most likely just end up having PHP do for me so i can have at least one performance tune. thanks for the input buddy.
05-09-2012, 08:27 PM
No problem man, looks like your truck as a pretty kickass suspension for those tires. I had a little bit of rubbing when I had my 35's but just barely. Looks like you plan on getting some nice BFGs in the future. Love my A/T ko's!!
 ... because Mike Rowe is just cooler than the other guys.
05-11-2012, 08:42 AM
the 4.6 will love 'em and your transmission will thank you
05-11-2012, 10:28 PM
2007 Ford F-150
that's what i was thinking too but i've had so many other people tell me it's going to be overkill for 35's. i'm inbetween on going with these or some 4.88's but if i do that i'm going to have to pay full price for a new set... so torn right now  also heard the 5.13's may not fit in my 8.8, know anything about that?
05-11-2012, 11:28 PM
Garage is empty, add now
Vehicle: 2001 ford F150
i hope you dont plan on driving on the highway.
2001 F150 5.4 ext. cab 4X4, 5" RCD susp. lift, PA body lift, 35" Toyo M/T's, 20x10 Fuel Hostages, SCT Livewire,
Ford Lightning Supercharger Swap @ 8psi Tuned by JLP, Custom E-fan setup
Built 4R70W by Darrin at BC automotive with Circle D 2400 stall converter
4.88 YUKON gears and DETROIT locker.
My videos
http://www.youtube.com/user/Itsahick?feature=mhum
05-11-2012, 11:43 PM
2005 Ford F-150
Vehicle: 2005 Ford F-150
this^^
05-12-2012, 12:43 AM
It will be a bit over 10% higher than 4.56 gears. So instead of 2000 rpms, probably closer to 2300 rpms at same speed. I really don't see it being that bad. It will be about the same as having 4.30 gears on stock wheels. 4.6 Punisher has 4.30 gears I believe so see what he says.
Higher RPMs doesn't necessarily mean more fuel burned if the engine doesn't have to strain.
05-12-2012, 02:54 AM
Is that so? datalog your mileage at 65mph and report back.
05-12-2012, 11:18 AM
i dropped almost 2mpg switching to 4.88's
My videos
05-12-2012, 01:28 PM
2007 Ford F-150
alright i think i may just fork out a little extra cash and get the 4.88's to be safe. now comes the decision on what locker/LS to go with. i was thinking truetrac or the yukon duragrip LS because i've heard pretty good reviews but now i've also been looking at the spartan locker. However, after reading some first hand reviews this is a pretty noisy unit and not sure on the durability. possibly even a lockrite locker. i mainly use my truck as a DD but take it out a lot on weekends and don't do much highway driving at all. Any input on this guys?
05-12-2012, 07:14 PM
Dang that's rough. I assume it was while using the same size tires, right? Tire Size? What gear ratio did you switch from, and how much of a power difference you notice?
05-12-2012, 08:51 PM
Quote:
what kind of off roading do you do? i have a detroit locker and it unoticable unless im in the snow, then it sucks.
yup, everything was the same. i switched from 3.55's and it was alot more responsive while driving for sure.
My videos
05-12-2012, 09:59 PM
2007 Ford F-150
right next to pismo/oceano dunes so a lot of soft sand and some hard packed rocky hill climbs closer in town. this open diff i have now is killing me...
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
