Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
V8 Engines SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 04-30-2012, 07:41 AM
2008 Ford Fusion
My Garage
Vehicle: 2009 Ford F150
That is correct. It doesn't conduct electricity, which makes it perfect for use on the boots to seal and prevent sticking. It also makes it the last thing you want to come between the coil and the plug.
Old 04-30-2012, 07:56 AM
Garage is empty, add now
Quote:
Very Good.
mh - A little more. -COP Ig boots are done like this. Once you slick up the ENTIRE inside of the boot, slide it over the spring. Now use a small screw driver or hemostats to pull the spring end from the end of the boot about a half inch or so. Swipe the end of the spring with Lacquer thinner. That cleans and evaporates fairly quick.
That's how you do it if you don't want to take a chance of having to go at it again in the near future.
Once clean and dry, let the spring go, it will recoil back into the boot. The coil is ready for mounting.
BTW- Make sure you use Dielectric grease that will not solidify over time. A lot of them do, - so read the back.
Old 05-03-2012, 07:41 AM
DO you think I should clean all the springs with lacquer thinner and reinstall them?
Old 05-03-2012, 11:09 AM
glc glc is offline
Vehicle: 2003 Ford F150
Yes.
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
Old 05-03-2012, 11:38 AM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman
I usually turn the coil about 10* so the mounting point pushes below the threaded portion of the cylinder head to insure it goes all the way down on the plug, then twist it back to bolt it in place.
sorry if that doesnt make sense in text form
Old 05-04-2012, 06:58 AM
Quote:
No, just the ends were they contact the plugs. Like I described.
Lacquer thinner works the best. Try to avoid getting it on the boots.
Other grease cutting agents may work as well. It's less work w/thinner.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
