Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
V8 Engines SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 04-20-2012, 10:25 AM
2005 Ford F-150
Vehicle: 2005 FORD F-150
fuel injector question
If a fuel injector is 'stuck open' would it pass a flow test?
Old 04-20-2012, 11:10 AM
2002 Ford HD #04417
My Garage
Vehicle: 2002 FORD/HD #04417
The shop where I work part time at has a protocol in place for injectors......
1. Before anything else they are cleaned and visually inspected
2. Each injector is then tested for leakage
3. Coil resistance is then checked along with opening and closing of the injector
4. All that pass the first three steps are then flow tested
So to answer your question a stuck injector should be found before the flow test....
But that's at this shop.....other shops may have their own proceedures....
Old 04-20-2012, 11:18 AM
2005 Ford F-150
Thanks for taking the time to respond. I asked this because I recently took my 05 150 into Ford Service Specifically for a diagnostic of injectors 5 & 6 this is what they say they did:
"Customer states check engine light on. Check 5 & 6 injector verify CEL on checked and found codes p0300, p0305, p0306 and p0316. Checked mode 6 data found misdata on 3 cylinders; 2,5,6. Checked injector flow found all injectors even flow.
Vehicle needs 2 coils, plugs and boots. Customer declined repairs owner will repair."
And I'm right back where I started with P0305 and CEL.
Old 04-20-2012, 11:34 AM
2002 Ford HD #04417
My Garage
Is this happening since you changed your plugs?
If so go through and check connections to the cops and injectors....
http://www.troubleshootmyvehicle.com..._testing_1.php
Old 04-20-2012, 11:35 AM
2005 Ford F-150
Vehicle: 2011 Ford F150, 5.0
Did you use dielectric grease on the boots?
Old 04-20-2012, 11:40 AM
2005 Ford F-150
Yes. Checked and re-checked.
Yes to Dielectric grease.
Old 04-20-2012, 11:59 AM
2002 Ford HD #04417
My Garage
Has the MAF been recently cleaned?
Old 04-20-2012, 12:09 PM
2005 Ford F-150
yes, with maf cleaner.
Old 04-20-2012, 12:10 PM
2005 Ford F-150
just did resistance check on injectors everything is 12 to 15
Old 04-20-2012, 12:12 PM
2005 Ford F-150
You can check for a leaking injector by pulling them, placing a rag under the rail and turning the key on. If you suspect on is sticking open, better not delay getting it checked out as it will hydrolock the engine.
Old 04-20-2012, 12:21 PM
2005 Ford F-150
I can tell you for certain that they did not pull the rail when they checked my injectors. There is still an even coat of dust/dirt on the rail. unless they removed it by using some mind power.
2005 Ford F-150
Quote:
I'm doing this now.
Old 04-20-2012, 01:15 PM
2005 Ford F-150
another ?: how hard is it to pull up the fuel rail? I have the bolts off and nothing budging. I also have the zip ties on already and they aren't on anything else.
Should I de pressurize before doing this?
Old 04-20-2012, 01:18 PM
Garage is empty, add now
Quote:
Gently, gently - the o-rings can stick some. Do NOT lose those o-rings....
MGD
Old 04-20-2012, 01:20 PM
2005 Ford F-150
Quote:
MGD
Roger. Do I need to de-pressurize?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
