Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
V8 Engines SPONSORED BY:
Thread Tools Search this Thread Display Modes
  #31
Old 04-21-2012, 05:03 PM
2005 Ford F-150
Vehicle: 2005 FORD F-150
My Ford Service Manual disagrees with you "Note: The DPFE sensor, EGR vacuum regulator (EVR) solenoid, manifold absolute pressure (MAP) sensor and the EGR valve itself are integrated into one unit in the ESM EGR assembly"
  #32
Old 04-21-2012, 05:23 PM
Garage is empty, add now
Vehicle: 2011 Ford F150
It's called camshaft retardation for short.
Women might not find ya handsome but they'll find ya in your F150
Ford Built_Ford Tough
  #33
Old 04-21-2012, 07:08 PM
Buddy.
IF you have a 2004-2010 5.4 L 3V engine, you do NOT have an EGR system, or ANY of it's ancillary components.
It is ALL handled via the PCM - VCT control.
Look elsewhere.
If you insist on believing otherwise, I/we cannot help you.
I challenge you to find an EGR valve or DPFE device on yer 5.4 3V engine.
I WILL eat my Depends - soiled or otherwise - IF you can provide definitive proof.
Be advised - I HAVE already exhaustively surveyed my entire engine compartment and ALL relevant factory documentation regarding this and have confirmed my findings.
Be prepared to eat Caca , lol. J/K
Papa Tiger nailed it, in essence
MGD
  #34
Old 04-22-2012, 12:09 PM
2005 Ford F-150
Quote:
Originally Posted by MGDfan View Post
Buddy.
Look elsewhere.
MGD
OK, ok. EGR dropped from list.
  #35
Old 04-22-2012, 12:37 PM
Vehicle: 2005 Ford F-250
I had 0420 and 0430 show up at the same time. Upon advice here, I changed out 3 of my O2 sensors (passenger side rear must have had fouled threads from the cats being put in).
Immediately I had codes for driver side heater circuit malfunction and passenger side stuck lean on the forward sensors. Fast forward 6 months (I don't drive it much) and I replaced both front O2 sensors again and no codes are showing up at this time.
  #36
Old 04-22-2012, 12:54 PM
2005 Ford F-150
Thanks for the advice Shuler. For now I'm going with some new crank & cam sensors (and if I still have 0430 I'll get some O2 sensors)
  #37
Old 04-22-2012, 02:14 PM
Vehicle: 1998 Ford F150 4X4 5.4L
Crap. sorry about that. Yea the one piece EGR system I referred to came in 04. But, I guess that was for the other V8. That's why it's in the manual.
MGD informed of this before, but it didn't take. Hope I didn't waste to much of your time. :o
  #38
Old 04-22-2012, 02:34 PM
2005 Ford F-150
np
  #39
Old 04-23-2012, 01:47 PM
Pull spark plug on #5 see if it is black, carboned bad/soot. If it is clean and looks normal look for another problem. Not an injector problem. If camshaft is loose/ broken chain tensioner/guide there will be cam codes probably. Since your confident it isn't a bad catz and you have no O2 codes look to a bad COP/connection or transformer coil. (s)/ cracked sparkplug. Use a mister at night/ spray a fine mist/don't wet the plugs/cops/ simply a mist in the air around them/closely/ If you see a blue glow/spark you have a leakdown in insulation. The cop is burnt or the plug is cracked.
  #40
Old 04-23-2012, 01:53 PM
2002 Ford HD #04417
My Garage
Vehicle: 2002 FORD/HD #04417
if by chance.....have you installed a rebuilt or aftermarket altenator recently????
  #41
Old 04-23-2012, 02:02 PM
2005 Ford F-150
Quote:
Neg. Still have original alternator. Were you thinking of that TSB where the alternator is throwing codes?
  #42
Old 04-23-2012, 02:03 PM
2005 Ford F-150
Quote:
OK I'll check, but just last week put in new COPS and Plugs. And I did have an P0430 code a day or two ago that hasn't returned, yet..
  #43
Old 04-23-2012, 02:17 PM
2002 Ford HD #04417
My Garage
Quote:
yep....if one of the diodes is going bad....it will throw some ironious codes ....makes for a big headache....
  #44
Old 04-23-2012, 02:57 PM
2005 Ford F-150
Adding to my list: Now I have raw fuel smell on startup. I love my truck, why does it hate me?
  #45
Old 04-23-2012, 05:05 PM
2005 Ford F-150
Now P0305, put an old coil in. Ok for about 20 min then knock, misfire then P0305. I dont have tools for compression test. I think i'll pull drivers side VCT and have a look. Sure sounds like something screwing with timing
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
