Home Discussion Forums Photo Gallery Vendor Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Ford & Industry News Vin Decoder Advertise with us
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Sign in using an external account
Register Forgot Password?
Look for a USED Ford F150
Carsdirect.com
Thread Tools Search this Thread Display Modes
Old 02-22-2012, 05:48 PM
Garage is empty, add now
Vehicle: 2004 Ford F-150
P0406 Code
I have a 2004 4.6L F-150. Just changed plugs and now is throwing a P0406 code (EGR position system voltage too high). There was nothing wrong with it prior to me changing the plugs however, I did unbolt the metal pipe that goes from the exhaust manifold up to the EGR valve, but I put it back on and made sure it was tight. Could this be the problem? Do I need to replace the gasket in there that I unbolted or is it something more serious? Oh yeah, in case the user name isn't clear, I'm no mechanic. Any help would be greatly appreciated!
Old 02-22-2012, 05:54 PM
Vehicle: 1999 Ford F-150 5.4
Did you mess with the 2 vacuum hoses that run into the egr pipe? might have replaced them backwards.
1999 F-150 xlt 5.4 4x4
1971 Mach 351c 5 speed TKO600 Tremac
Old 02-22-2012, 07:25 PM
no, i didn't remove them. I just got a new gasket so I'm going to try to replace the old one and see if that solves the issue. It ran fine for about 50 miles of hwy driving 70-80mph, then the engine started to stutter real bad
Old 02-22-2012, 08:50 PM
well, replaced the gasket only to find that there wasn't one on there at all. now the CEL is on and the codes are P0307 and P0316. Any suggestions?
Old 02-22-2012, 09:01 PM
what plugs did you use? Those are missfire codes po307 is # 7 2nd one back on the drivers side. Check to see the coil is plugged in good.
Old 02-22-2012, 09:43 PM
i used autozone's brand. i'm gong to change the plug out and swap the coil with another one and see what happens.
Old 02-22-2012, 10:02 PM
Your going to get misfires with those plugs. Modular engines are very picky about plugs. Motorcraft only..
Old 02-22-2012, 10:40 PM
alright well looks like i'm doing another plug change. thanks for the info. i'm sure i'll be back on here soon.
Old 02-23-2012, 12:20 AM
changed the plugs and it runs like a top! thanks for the help!!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
F150online - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Contact Details
