Spark Plug Stuck - Dealer Sticks Me?
Help - The Ford dealer has my 2006 4x4 and can't get the last plug out. All 8 plugs broke off and now the last one will not come out. He thinks that they will have to take the head off to get it out. Price could reach $4500.00
My truck has 99k miles and Ford recomends we change our plugs at 100K miles.
This my friends, is a defective plug that should have been recalled by Ford.
Any advice...... Any help from Ford?
They want to know what I want to do Monday. They even talked about replacing the motor....7K plus,
Some tune-up, the truck was running pretty good when I took it in. I made the last payment 3 months ago.....Now this!
If your dealer is so stupid they haven't learned how to extract broken plugs you need to get it out of there ASAP. This is a well known issue and a qulified dealer could extract that plut for less then $100 per broken plug. I bet your dealer didnt even follow the Ford spark plug removal TSB. Call a wrecker get it out of there.
Ask your dealer if they have tried using the Lisle #65600 tool. It works great & Lisle has a tech line that gives free advice. Can buy the tool for 50$.
http://www.tooldiscounter.com/ItemDi...le&kw=LIS65600
60k
First- Ford has lowered the plug change interval. I change mine every 60K.
Second- Their is a "How To" article titled "New method to extract porcelain from broken spark plugs" - some nice little tricks.
https://www.f150online.com/forums/ar...ark-plugs.html
Nine times out of ten if it won't come out with the Lisle tool its because they still have a short piece of the wire electrode intact. The wire will bend within the shield from the pusher tool and prevent the tap from screwing in far enough to catch and pull the shield out. I have used a medium size flat screwdriver forced by hand down into the shield then rotate the screwdriver back and forth until that wire breaks off. The tap will then screw in far enough to extract the shield. The Lisle tool has never failed me out of many trucks and dozens of plug removals that others have broken plugs off in. If they broke all 8 off then they have no clue what they are doing...Just my experience. Sounds like someone wants to make some money this is not a major repair job anymore using the Lisle 65600.
One other tip, use antisieze on the shield section only for easier removal in the future. Be sure to keep it off the electrode.
Well, it just got worse. I was on my way to the dealer when they called to tell me that the shield has pushed down into the cylinder. They did use the Lisle tool and the top ring of the shield snapped off. They let it soak over the weekend and this morning tried one more time and pushed it in. Current bill $1200.00. Remove the head and get the shield out......$4300.00. They had 3 different mechs working on my truck. The worse tune-up they have ever seen. One comfort tho, a new eng is only $7800.00......
If I buy the bullet, will someone shoot me in the head?
on
