5.0 engine knock
Old 11-13-2011, 12:22 PM
sandnat24's Avatar
5.0 engine knock
Anyone had problems with the engine knocking? I just got my 2011 F150 2 weeks ago it has 390 miles on it. Once everything's up to temp (engine, trans) in gear at an idle you can hear a slight knock. If you give it a little gas the knock becomes very pronounced. It is not noticeable at highway speeds. trucks at the dealer. waiting on a diagnosis.
Old 11-13-2011, 01:05 PM
I think you are the first one to post a knock. Mine has 9,200 on it and still quiet. keep us posted.
Old 11-13-2011, 01:11 PM
06yz250f's Avatar
^^This at 8100 miles.
i did get a check engine light the other day, had it turned off and it hasn't come back thankfully.
Old 11-13-2011, 01:32 PM
sandnat24's Avatar
I read TSB on a drive shaft knock. Hope that's all it is. To me it sounds like a rod knocking. We'll see what the dealer comes up with.
Old 11-13-2011, 01:43 PM
glc is online now
You didn't read out the codes?
Old 11-13-2011, 03:42 PM
06yz250f's Avatar
i did. it's in my "im back" thread. 2 codes that were the same for emissions sensor
Old 11-13-2011, 04:25 PM
SLW-SVT's Avatar
TRUCK OF THE YEAR - 2011
its definitely under warranty..
Old 05-23-2012, 10:59 AM
Btello1978's Avatar
Recently started to knock and I have only 5000 miles on it. Took it in and they said there's a service bulletin for the timing chain that is needs a tension pin changed. They said it can drive great for the life of the truck without effecting performance. It's just more of an annoying problem especially since its a brand new truck
Old 05-23-2012, 11:09 AM
glc is online now
Are they going to replace it under warranty?
Quick Reply: 5.0 engine knock
