Differnece between GT 4.6 and Triton 4.6
The following users liked this post:
its not just the motor fitment you need to be concerned with, you need to consider routing around things such as the frame, starter, steering column.
This topic seems to come up frequently, that is guys looking for an s/c for the newer 4.6's. If I was to embark on the journey to a have new model 4.6 blown, I would start by looking at the 03's to see what the difference is from old body style to new.
Why would Ford reinvent the wheel as far as the engine package is concerned just because the body has changed? So much of the small stuff can be moved around under the hood, and with an air/air intercooled centi, almost anything would be doable. If the s/c mounting brackets were compatable from 03 to 04, then the rest is just frustration!
