block heater vs. oil pan heater
Forgot to mention -
If anyone is looking for another way to keep the battery warm, check out Schumacher's 1.5 amp battery maintainers.
They come ot two styles - the portable ones with various connection options (cig lighter, alligator clips, etc), and a sealed permanent-mount version you can bolt into the engine compartment and hard-wire to the battery. Plug it into the same cord as yer block heater or whatever.
This not only keeps the battery warm internally, but ensures it's always fully charged at the same time.
MGD
MGD
359d9bc0.jpg&t=1
With a gas engine I dont think this is necesary unless you are talking about a constant sub zero temps for multiple weeks months. Ive had two diesels and rarely plugged them in without much of an issue. Only time I did was maybe a week out of the year when it got below zero and then I would it on a timer.
You plug one of these in and your e bill will go up. Dont waste your money.
Remote start end up being cheaper in the long run. At least in diesels thats not how the block heater really worked. Never used mine and got into a warm truck instantly it only made for easier starting. Like I said waste of money. Get a remote start.
A tank type circulating block heater is the only thing that will warm up the entire engine.
http://www.amazon.com/Kats-13150-Alu.../dp/B000BQUUR6
http://m.northerntool.com/northerntool/product/detail.do?itemId=174050
bwhahaha let me tell you guys about cold weather, 79rocket can back me up. It's been -25* here every morning for the past week, warmed up to -10*...
Get a BLOCK HEATER before anything else. That's the only thing that will actually warm your engine up. fwiw, all vehicles sold new in Alaska come standard with block heaters.
If it makes you feel better you can get an oil pan heater, its not needed unless you're up here, but it does help.
I have both of those and a trickle charger all hardwired in. I did this because I was going to school in Fairbanks (They've been having -45* the last week) and didn't want to freeze my battery. I actually had a battery die because I let it sit for 5 days over break with temps getting below -30*.
Here's a friend of mine on Sunday in Fbx
