95 F150 shut off
Old 06-14-2010, 08:41 PM
gavin630's Avatar
95 F150 shut off
My truck sputtered and then shut of and now it will not start.
Old 06-14-2010, 09:02 PM
jgger's Avatar
Need gas ?
We need a little more info than that!
Old 06-15-2010, 06:02 PM
gavin630's Avatar
I was driving down the road and my truck turned off. I had plenty of gas. Changed tanks and still wont start. Replaced the fuel filter and then unhooked the line and turned the engine over and the fuel pump is pumping gas out like it should be. Not sure what to do now.
Old 06-15-2010, 08:05 PM
Labnerd's Avatar
That's not a lot to go on- it just quit running. You may have an OBDII system in the truck and most parts houses have scanners that will read any codes. They actually put the OBDII system in the 1995 1/2 YM F150. If you have the old OBD system you'll have to find a scanner for it. They're generally pretty cheap on fleabay. But to give you an idea of what's wrong would be a broad guess at best. Check all wiring and all vacuum lines. Look for anything burnt. It could be as simple as a wire came loose. Check the coil wire and plug wires too.
Old 06-16-2010, 01:29 PM
gavin630's Avatar
My truck is a 95 f150 4 x 4. Thanks for the help.
Old 06-16-2010, 01:43 PM
glc is offline
What engine and transmission? How many miles on it and what is its maintenance history? Have you checked for spark?
Old 06-16-2010, 04:03 PM
gavin630's Avatar
5.0, not sure of transmisson, 184xxx miles, will check spark when i stops ranning
Old 06-16-2010, 04:17 PM
glc is offline
You don't know whether you have an automatic or manual?
Old 06-16-2010, 04:34 PM
gavin630's Avatar
automatic
Old 06-17-2010, 06:51 PM
gavin630's Avatar
no spark and its giving me a bad egr valve code. Could a bad egr valve make the truck shut off and not start?
Old 06-17-2010, 09:40 PM
gavin630's Avatar
any suggestions?
Old 06-18-2010, 12:36 AM
glc is offline
No spark? That's a problem in the ignition system. A bad EGR won't cause that. First suspect would probably be the ignition module.
Old 06-18-2010, 06:27 AM
gavin630's Avatar
Where is that located on the truck?
Old 06-19-2010, 08:03 AM
gavin630's Avatar
will its not the ignition module. Whats next?
Quick Reply: 95 F150 shut off
