Cam Phaser Replacement Costs
Old 03-30-2016, 10:55 PM
ptblunt1's Avatar
Cam phaser
Originally Posted by Rold0609
I can install for $500
I will fix it right the first time its about a 10 hr job
Im in NC
Hello I was wondering if you was still doing the Cam phasers for 500.00 and what part of NC are you located?
Old 03-31-2016, 02:49 PM
daaanyelle's Avatar
My total bill was $2,475.31 (with my discount) for the whole works to be done last July.
Old 06-28-2017, 07:31 PM
Anderson1030's Avatar
Cam phaser
Im in NC
Are you still doing Cam Phaser. I live in Spartanburg SC. I have a 04 Navigator. It rattles when you start it up after it has been setting
Old 06-29-2017, 12:21 AM
glc is offline
Fram oil filter? Get rid of it.
Old 01-12-2018, 02:47 PM
Clleatherman's Avatar
Nc f150
Im in NC
Do you still do mechanic work? I have a 2009 F150 5.4. I'm thinking about installing the cam phaser lockout
Old 03-29-2018, 11:36 PM
Taggartlarry's Avatar
Cam Phaser replacement cost
I have a 2005 F150 5.4 3v. Truck has 103k on it, everything is in excellent condition other than timing issues. When I bought the truck back in 09 with 42k .I had to force dealer to replace phasers after owning truck for one week. Everything was great after that. Than last year had phaser issues again replaced the phasers, oil pump, oil pan front and rear seals ran ok. Than two weeks ago started to get the tapping than diesel sound threw a code cam position sensors, replaced both problem was still there. Replaced Both VCT's and the truck ran like a champ for two days. After replacing pulley's and tensioner the truck would hardly run threw a p0012, p0172 &p0174 code. had a friend with a scope captured the stats when code was thrown. And yep Cam phasers are bad. Again.
Old 04-13-2018, 04:19 PM
lad2006's Avatar
Cam Phaser Install
Hello - I have a 2005 Linc Navigator. Are you still doing Cam Phaser Installs ? What part of NC are you located.
Thank you
John
Im in NC
Old 01-07-2019, 03:06 PM
Poppy2's Avatar
Im in NC
Where are you in NC? Thanks, I am in Wilmington and need cam phaser 2006 King Ranch
Old 03-01-2019, 12:56 AM
Magzf150's Avatar
Im in NC
where in NC? I’m in sc and I need mine done 😂 all my quotes are HIGH
Old 03-01-2019, 09:27 AM
Poppy2's Avatar
Cam Phasers
Anyone here doing this type of work in NC reasonably?
Old 01-22-2020, 08:55 AM
Cam phaser
Im in NC
where in NC are you located I'm having a problem with my cam phaser I'm located in hendersonville NC get back to me if u can help my email is Guillermoescobedo15@gmail.com thanks
Old 02-25-2020, 11:54 AM
Jeyna Griffin's Avatar
They're charging me 4000 to fix the phaser on a 2010 ford flex
Old 02-25-2020, 02:27 PM
glc is offline
Different vehicle and engine.
Old 12-06-2021, 09:39 PM
jt mechanic's Avatar
What can happen
Originally Posted by l337viton
Just out of curiosity, besides the noise, what are the results of driving around with bad cam phasers?
I had a camphaser explode and throw the timing chain and destroy the valve cover and camshaft also some of the roller rockers were damaged also
Old 10-12-2022, 01:30 PM
MIKEEDEE1's Avatar
2019 lariat
So how do i know if i need to have a Ford rep look at mine. It rattles like a diesel at first start.
Quick Reply: Cam Phaser Replacement Costs
