Spark plug change 2002 f150 5.4
My 2 cents: When I change modular plugs the fuel rails stay on exactly for the reasons the op mentioned. I really hate to mess with the injectors and risk losing or damaging an o-ring if I don't have to. It really isn't that hard with the rails in place.
I also get a little confused when people talk about using universal joints when changing plugs. Granted, I haven't done a lot of modular tuneups, (maybe half a dozen, probably half and half 4.6/5.4?) but I've always been able to get a straight shot at all of the plugs with the right combination of extensions.
Put me down as a member of the no antisieze club. You guys can argue all you want about whether it makes the plugs back out. I personally don't like it because I changed a set of 4.6 plugs a few years ago that had been put in with antisieze. It left the threads in the heads all gummed up and made it VERY hard to tell if the new plugs were going in straight. There were a couple of plugs that I honestly couldn't tell whether or not were crossthreaded until they tightened down. That experience really turned me off to using antisieze.
Good morning Mr. Sultini!
Sir - that was uncalled for. He is a nice young man who answered yer questions and was just trying to help.
No need to throw insults, sir. and - There are some good folks in Texas. Last I checked it was still part of the US of A too.
By the way, yer posting history leads me to wonder if you would be better served by screen name like 'insultini'
Have a good day, sir.
Cheers
MGD v4.2
Cheers
MGD v4.2
#1 I didn't ask any questions
#2 I am sorry if I offended anybody
#3 I never said anything bad about the State of Texas
#4 I never said the state of Texas was not in the USA.
#5 Sounds like you are insulting me when I didn't even talk to you( Insultini)
#6 Maybe you should change you name to F150fella08FAN.
Have a very nice weekend Sir.
Originally Posted by sultini
MGD
I have a question for you MR. with all the universals and different sockets on such angles going into the head do you really think you can get an accurate torque on the plugs?? If so enlighten me then we'll both know.
When I was in the service I kicked a couple of guys A--es now that I think of they were from the Lonestar State.
Here's an example: You **** & moan about a job that takes me all of 1-2 hours to do (and I'm SLOW... there's folks who can do a 2V in 30 minutes, no chit) - and that's with one hand, since the other one has a beer in it at all times. I Pray you never own a 3V with the 2-piece plugs!
Sir - Please know that, if you have any legitimate non-confrontational questions I will do everything in my power to help you. That IS a promise.
But... Don't, tacitly or otherwise, threaten kids. Not. Cool. Clear?
MGD v1.0 Yeah - it's been re-awakened for a special occasion.
On the bus!
1. This is what is known as a tacit threat: (is that too large a concept for you?)
2. The nice young fellow in question is just 18. Around my parts, that's not even drinking age - hence ... a kid. And in this particular case, a very personable, decent one.
So, tough guy... You do the math.
Just what we need, another Freakn' ITG
EDIT: So, sultini, whaddaya say, ya wanna get back on topic and continue discussing spark plugs, or what? Check out Denso Iridium IT-16's for the next swap. They are superb. Their install procedure has not changed (and they include both with antisieze and without) http://www.densoiridium.com/installationguide.php.
MGD v1.0
Man/Boy you are a real Wise A--, I am suprised the moderators didn't throw you off yet. you really know how to break them. When I was in the service I kicked a couple of guys A--es now that I think of they were from the Lonestar State. At least after all that you admitted you didn't torque your's either. You know what they say, just because your doing something for a long time don't mean your doing it right I'm referring to your post numbers.
MGD v1.0
Maybe you boys should have a few beers and see who can pee the farthest. Until then...
Is it ok to use wd40 on the injector o rings? Im in the middle of a swap and will be installing the fuel rail shortly, any tips like that to help make it go smooth help.
I was working on my lifted f150 once, using a plastic cooler to stand on. Was leaning in the engine bay pulling the throttle body and IAC. Got to much of an angle and WHOOP, cooler came out from under me. At the time I was unprepared and only had one hand holding me up since the other had a wrench in it. Needless to say I think the hood latch assembly left a nice mark across my chest and in the heat of the moment to catch myself, I jammed my hand in some places not meant for hands. Came out nice and scrapped up. Won't stand on plastic anymore, atleast not on a smooth surface. Started using a ladder after that...
Here I sit dirty nails and a beer just took a shower after a day of plug changing. What a trip. Couldn't have done it with out info from this site.
Fuel rails I removed them lost a o ring had to buy a kit for $10 the plugs were not a problem I used a magnetic 5/8 long with a swivel attached couldn't have done it with out it, well could of but didn't want to. The biggest problem I had was my own fault I didn't lubricate the o rings on the fuel rail when I went to put it back what a D---. took them back off and the o rings and hit them with WD40 the rail went on like butter. I also lowered the front end but still had a problem with the old metal milk carton holder it kept slipping out from under my feet. Truck has 109K first plug change and now done for 100 K more. The plugs looked almost new. The truck was running like a rapped ape before changing and after just thought it was time and the weather was great. Hope the neighbors forgive me for the langauge and mean mugs. Used OEM motor craft from dealer. Next time like butter. OH!
I also used a little anti seize on the threads.
I think you buys should have a few beers and see who can pee the farthest. Until then...
LOL @ pissing contest. Y'know, if I thought it would help mend fences I'd be all for it - I'd need to let 'im win though
This won't help much with yer monster, but I deflate the front tires to lower it a bit. And put a padded moving blanket on the front to take the 'edge' off, lol.
WD-40 - that's what I've been using. For better or worse (very small quantity).
Good luck sir!
Cheers
MGD v4.2
MGD
Nasty.. vindictive ...evil.... egomanic....know it all....too many toys and not enough brains, no friends after how many posts (5000) 2 FRIENDS DOES THAT TELL YOU SOMETHING.
No follow up please I am done with you MR. twister.
PS: How come you know how old people are on the site you sound like you got a problem with younguns? I don't look up people's ages.
I will not respond anymore to your foolishness, I sure would like to have a contest with you but it wouldn't be how far.
SULTINI OUT
SULTINI OUT
THANKS
It was a rough day it wasn't because of the plugs it was my stuff, dropping bolts to hard to reach areas, fuel rail no lube on reinstall, slipping milk carton.
Been doing Mechanical work many years and read a lot of info on antizieze pro and con decided to go with as I have also used it many times over the years. Just a dab
NOTE: The cop's don't float as some people on here would have you believe all mine were solid tight from factory. So don't take every thing here as gospal just take what you need and use your own common sense.
24 inch lbs on the coil hold downs. Yea, the engineers spec that for a reason, it's been posted here many times. I'll explain it again, if this becomes necessary lol.
You can use anti-seize, but you must reduce torque X 30% as a general rule, but the general rule of thumb only applies under normal circumstances. For 4 thread modular heads, anti-seize isn't needed nor is this considered a normal/general application. 9 thread plug chambers would be the general/normal, so the given reduction in torque value wouldn't be X 30%, it should actually increase mathematically. Adding it, your taking chances.
There's no "pro's" in doing so, not for this application. The "con's", -are plenty, so why chance it and being a mechanic for many years, why are you still using a milk carton to stand on, -that's a PITA. There's a much safer/better way, but some will never learn I guess, they know to much already.
anti seize
My factory manual says torque the plugs to 8 ft/lbs which is ridiculous. I torqued them by hand like always to what felt right.
I used the correct Motorcraft plugs bought from Advance Auto Parts for $2.xx apiece. The dealer said if they changed the plugs, they charged $10 each for the plugs. Oh, and the plugs did not have nickel on the threads, maybe on the body.
