98 f150 "system too lean"
Hello! looking for help or guidance with my 98 f150...its a triton v8 4.6....For the first time since I've owned the truck, the check engine light came on. I'm in a bit of a spot where I have no help really, and I'm LOST as to where to begin dealing with this...I'm capable of minor repairs or changing oil...usually anything Im able to get info on....but I stopped at an auto place and the guy said," its ok, you got two "system too lean" reports or errors"??? He said it meant that the oxygen to fuel ratio was too rich in oxygen when it entered the combustion chamber........but that its fine, drive it....Seriously, that's nice, but is it true? I've found it easier to fix s*it b4 its broken too badly, I need my vehicle and a second (or more) opinion on the "it's fine"....plus she's been sucking gas more than normal = )
Sucking more gas than normal could just be the fact that you're probably using a winter fuel blend which is less efficient.
Your check engine light could also be from failing upstream O2 sensors. They're what report rich/lean conditions and they become more and more inaccurate as they age. They're supposed to be replaced every 100k so it's worth looking into.
