Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Ford & Industry News Vin Decoder Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
New! Use your Facebook to securely log into this site, click logo to login
Thread Tools Search this Thread Display Modes
Old 02-12-2010, 10:30 AM
Replaced the coil but must worse
While I am SICILY (ITALY) I have a 5.4 V8 in 2004, I am writing USING THE GOOGLE TRANSLATOR, I replaced all the packages imported by the U.S. before were evil seems to go to 7, after replacing WALK NOW WORSE, NOT HERE Extremely skilled ON THESE MACHINES, PLEASE HELP ME!
Old 02-12-2010, 03:54 PM
Vehicle: 2003 Ford F150 FX4
I need a translator to translate the Google translator.
I think you are saying you ordered 8 coils from the US and put them in and it runs worse. Is that what your telling us?
If so what coils did you order?
Is the check engine light on?
How many miles on your truck?
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, Troyer E-fans, True Duel Straight Pipes with X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Old 02-12-2010, 05:55 PM
Vehicle: 1997 Ford F150 4.6
I think he has a miss on #7 after changing the cop's ?
Old 02-13-2010, 10:11 AM
Wow after translation of the translation that I do not speak either of trucks
Old 02-13-2010, 10:27 AM
Vehicle: 2007 Ford F150
Quote:
Bien venuto nel forum del F150
Che cose e il problema? Non si capisce bene? Proviamo di aiutarci.
Old 02-13-2010, 10:49 AM
ciao, il camion ha 57950 miles ho fatto cambiare le bobine 8 perche da qualche settimana non andava bene, le bobine sono marca summit
Old 02-13-2010, 11:25 AM
Old 02-13-2010, 01:04 PM
8 COP IGNITION COIL summit
Old 02-13-2010, 01:37 PM
Vehicle: 2006 Ford F150
wow...
2006 F150 XLT 5.4 4x4
Performance: Cheap ebay CAI w/ K&N filter, Delta Force tuning
Exhaust: Stock manifolds, NO cats, 2.5" true duals, Magnaflow X pipe, Borla Pro XS mufflers, 3.5" stainless tips
Other mods: Nathan Airchime K5HA locomotive horns
Videos:
Borla kick down
Borla idle, rev, and hammer it
Borla cold start/inside cruise
Nathan Airchime K3LA
Nathan Airchime K5HA - short burst
Nathan Airchime K5HA - time delay
Old 02-13-2010, 06:27 PM
Ok what he's saying is he replaced his coil and it's running worse any sugestions i'll try to translate i'm not to familiar with italian automotive terms
Old 02-13-2010, 06:33 PM
Sounds like he missed the plug(s) with the COP. Hard to do but possible.
Old 02-13-2010, 06:59 PM
dicano che forse hanno sbagliato a mettere le bobine e hanno sbagliato forse a metterle nella candela
Old 02-13-2010, 07:31 PM
Vehicle: 1998 Ford F150 SC 4X4 5.4L
Quote:
I did that before, - the boot bottom edge caught the top of the plug and folded in half. That is hard to do, couldn't do it again if I tried.
Old 02-13-2010, 07:33 PM
Vehicle: 1999 Ford F-150 5.4
Make sure to use MOTORCRAFT spark plugs.. Dielectric grease on the boots and torque them to 28 lbs.. Its not unheard of for a coil to be bad out of the box so if the plugs have been changed (with MOTORCRAFT only) try moving the coil to another cylinder.
Old 02-13-2010, 08:36 PM
if some one can take a look at his profile he has pictures of his on board computer diagnoses maybe that can help solve his problem
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
