I have a 4.6l in my truck it has 73000 on it, and when i first start it up when its cold, it will make a loud, noise like a pump is dry but it sounds like its the main belt, i cant figure out were it is coming from at all, do people put belt dressing on there belts, idk any help is greatly appreciated, thanks
what kind of noise? if it is a squeal then replace the belt.
could be some other things but it's best to start with the belt and go from there.
__________________ 2002 F150 FX4. Black two tone. Extended cab.
-SI/DO flowmaster catback
-AFE cold air
-EDGE Attitude. Level 2 Custom.
-Headmaster Shorties. One cat for each side.
-305/70R16 ProComp Xterrains-16" American Racing rims.
you could use a mechanics stethoscope to find it available at a local harbor freight for a few dollars or the old long screw driver trick to find the squeeler. my bet is going to the the ac compressor I have seen the bearing go on many of those. I had to replace the same thing on my 99 f150 for the same reasons and it was a pain in the butt to do. and it sounds like I will be doing it on our 00 expedition soon as it is starting to give the squeel. some have had the bearing go in the idler pulley as well. just give the stethoscope thing a try to be sure. GL
