F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 11-07-2009, 07:12 PM
small red hose from firewall??
I was changing my sparkplugs on my 94 f150 302 and I broke a small red plastic hose. It starts at a can shaped thing on the firewall curbside and then runs behind the motor with a green line the come from the egr. Basically I would like to know what I just broke and what is my truck going to do when I start it up?
Old 11-07-2009, 07:15 PM
the can thing say siemens on it with an arrow...
Old 11-07-2009, 07:19 PM
Vehicle: 2001 Ford F150
Vacuum accumulator for hvac
Old 11-07-2009, 07:28 PM
so is that going to make it operate differently? I'm in SD dont need ac at the moment.
Old 11-07-2009, 09:44 PM
glc glc is offline
Vehicle: 2003 Ford F150
You will probably have a vacuum leak. You can splice it with a length of standard vacuum hose.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 11-08-2009, 11:52 AM
Most likely will have a rough idle and your blend door will not move so your heat and ac settings will be wrong. Glc is correct.
Old 11-11-2009, 10:47 AM
Vehicle: 1983 Ford Bronco
Read the vacuum map on the emissions sticker under the hood. Red is the vacuum line from the intake manifold to the reservoir (coffee can), so you'll have a vacuum leak (high idle, dirty air into the engine). That reservoir is for the 2ndry air system; the HVAC reservoir is glued to the evaporator cover, under the foil-faced fabric.
You can fix it just like this:
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
