F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 11-07-2009, 12:32 PM
Vehicle: 1974 Ford Ranger
Fan Clutch?
There were 2 things I was going to replace on my 04 F150 when I realised maybe only one is the culprit. The truck rarely reaches standard operating temperature, I assumed the thermostat was stuck open.
But I have a second problem, I am sure fan clutch is shot because most of the time it roars like a semi tractor off the line. Could my engine not be warming up because the fan is contantly pulling too much air? (due to the clutch sticking) To determine if my fan clutch is indeed shot, I am wondering how freely the fan is supposed to spin by hand when the truck is off, if I give it a push should it keep spinning, or will there be more resistance than that? I can move mine, but it will definitely not keep freewheeling.
Old 11-07-2009, 02:19 PM
glc glc is offline
Vehicle: 2003 Ford F150
It's more likely the thermostat - if the thermostat is closed, the coolant is recycling within the engine and it doesn't matter how cold the radiator is.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 11-07-2009, 03:18 PM
Quote:
If the thermostat was closed wouldnt the engine run hot?
Old 11-07-2009, 03:25 PM
Vehicle: 2009 Ford F150
sounds like the heromstat is stuck open did you try taking the radiator cap off and seeing if you can see coolant flowing constantly? also the clutch fan could be the problem too, i have seen a stuck fan clutch cause low operating temp. it should have little resistance you should be able to spin it and for it to rotate 1/2- 1 turn before stopping, if you really have to push it, its not operating correctly.
Old 11-07-2009, 04:28 PM
glc glc is offline
Quote:
If it's STUCK closed, of course. The function of a thermostat is to open and close to keep the coolant temperature as close to the rating as it can. When it's closed, the coolant recirculates in the block, when it opens, it circulates through the radiator.
Old 11-07-2009, 05:25 PM
Vehicle: 2002 Ford F-150 5.4L
Even when a thermostat is fully closed, even stuck closed, some fluid still circulates through the radiator...rough guess about 10%. When it's really cold or you have a really efficient system, this can very well be enough circulation to keep the engine at a perfectly normal temp with the thermo closed. Does happen. I have a F250 radiator in my truck and this time of the year especially on the freeway, I see engine temps hanging around 185*, and that's with a 195* thermo.
How are you verifying the water is not reaching a normal temp? Do you have an aftermarket gauge or is the stock gauge not reaching a position that you normally see?
So most likely, if it's not reaching temp for sure, then the thermo is stuck open. Even if the fan were cooling constantly, it would not fully overpower a normal working thermo and keep the engine too cool.
The fan should turn by hand when cold relatively easy, but you shouldn't be able to swing it around. I've never had one that would make a whole bother revolution on it's own.
'02 F150 XLT 4X4 SCrew. 5.4L
K&N FIPK/Amsoil Filter
Flowmaster 40 si/do Exhaust
325/70 16 Nitto Terra Grapplers
16X10 MB Motorsport wheels
4.10 Gears
Rancho 4" lift
Edelbrock Extreme Travel Resi Shocks
Autometer Carbon Fiber Oil/Trans Temp Gauges
Carbon Fiber Interior (www.dash-kit.com)
Peterson Fluid Sys. Remote Oil Filter
FTVB
Troyer Performance Electric Fans
Underdrive Pulleys
Amsoil Fluids Throughout
My SCrew'd Garage
Old 11-07-2009, 06:24 PM
Thumbs down
The stock guage is not reaching the half way point, (not even close) and the heater is only blowing warm air when the engine finally does warm up (which is taking longer than normal.)
As for the fan, I think the clutch must be shot then, because, yes I can move it but it seems to have more resistance than what it should, according to the results I have found. It stops as soon as I let go after giving it a push.
It must be a combination of both the thermostat being stuck open and the fan clutch then.
Last edited by Kellxr7; 11-07-2009 at 06:28 PM. Reason: edit... why is there a little thumbs down at the top of this message ? lol.
Old 11-07-2009, 07:33 PM
I'm still going thermostat. I don't think you're getting what most of us have said...even if the fan is bad, if the thermostat was working normally it WOULD NOT run that cool.
Before I ran out and bought a new fan, go compare yours to a new one or someone with an old one to make some comparisons.
You've also got to keep in mind, that fan still works when it's cold. Even though it doesn't bite as much air when cold, that suckers pretty efficient and still draws quite a bit of air. I personally think your fan is fine.
4.10 Gears
Rancho 4" lift
FTVB
Underdrive Pulleys
My SCrew'd Garage
Old 11-07-2009, 08:10 PM
Vehicle: 1998 Ford F150 4x4 5.4L
The 192's work best IMO. Stay away from the 195's . I tried them all and even replaced the clutch fan. Same problem. Went with a 192, -problem gone.
BUT - I did this with a 98 model.
Old 11-07-2009, 09:08 PM
192 / 195...what ever. I was referring to what ever stock is. Since you introduced it though, I don't possibly see what difference three degrees can make. I'd bet those things aren't even contstructed / calbrated to a three degree tolerance.
4.10 Gears
Rancho 4" lift
FTVB
Underdrive Pulleys
My SCrew'd Garage
Old 11-07-2009, 09:22 PM
Clutch Fans very rarely go out. When they do, it's because they loose their seal. Signs of bearing fluid leakage is a sign.
Old 11-07-2009, 09:35 PM
glc glc is offline
No logical reason why a 195 would not work right where a 192 would, but stranger things have happened. Brew got a bit upset about what Galaxy said but he thought it over and fixed it.
Old 11-07-2009, 09:37 PM
Alright.
Old 11-07-2009, 09:56 PM
Thought it over
Old 11-07-2009, 10:13 PM
Vehicle: 2002 Ford Expedition
The fan clutch in my 2002 5.4 liter was bad...evidenced by roaring fan at all RPM levels. Temperature never seemed to run any cooler however...which makes sense since during 90% of driving, even with a stuck clutch, the fan wouldn't be turning that fast.
If your truck is roaring though...best to replace the clutch. Easy job for the most part. I side with the others and say do thermostat too.
2002 Expedition 4x4 XLT
285/75/16 Uniroyal Liberators
Bilstein Shocks, Straight Exhaust, Gotts Mod
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
