F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 11-03-2009, 06:21 PM
Vehicle: 2000 ford f150
need a replacement engine
I was on the highway the other day and all of a sudden the motor starts running on 7 cylinders. I checked the codes and it came up P0308. I went to pull the plug and found it loose and when the plug came out it was missing the center electrode and was beat up pretty bad. I tried a new plug and got nothing and switched COP's and still is missing. I'm going to check the injector just in case it leaned out and burned it up and a compression test before I start tearing everything out but I would say it is toast. The motor (4.6 romeo) has 225 000 km on it so would you even recommend trying to fix it or just put in a replacement. I am leaning towards a used motor but I can only find one that will fit a 2000. I read posts on 01-03 with the PI heads but will it work with my computer without any mods? Also I am interested in using one from a crown vic but I don't know what years will work. Thanks.
Old 11-03-2009, 07:38 PM
Vehicle: 1993 ford f150 xlt
92-2000 4.6 2v(car and truck engines) have the npi heads and will bolt right in. just use the truck intake. or you could stick an 01-03 4.6 2v(99-04 mustang gt's had pi heads as well) in it and make a few minor changes and have the pi heads with the stock npi tune and be perfectly fine. i'm pretty sure the only changes that will be needed is tap a hole in intake coolant crossover for temp sender, and i think something about the throttle cable bracket would need to be changed or modified. but i could be wrong about that.
Old 11-03-2009, 08:52 PM
Vehicle: 1997 Ford F150
Before you go through the new engine hassel. Remove the cam cover and check for a follower off on the cylinder that was affected. Number 8 I assume. Sometimes a piece of debris from the plug will get lodged in one of the valves and hold it open this will do two things. One it will lower compression so you can't get a air fuel mix and therefore no combustion. Two when a valve is held slightly open the follower will usually fall off. Reinstalling the follower may work but there is a chance also that if this happened the valve may be bent as well from hitting the piston. You never know sometimes you get lucky. I just think it may be worth it to check it out first. Good luck.
Old 11-04-2009, 07:00 AM
Thanks! I'll pull the valve cover tonight or tomorrow to check that. For the crown vic change over I found a running 94 for $400 yesterday so I may do that if I have to. Easier to check the valves first though.
Old 11-04-2009, 09:08 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Your 2000 is a NonPi engine but any 4.6 truck Pi engine will work. You are fortunate in that your truck has COP ignition making it easier to swap. At this point you could easily swap for a 5.4.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 11-07-2009, 08:56 AM
Just going out now to pull the motor. I was on the phone all week to find a replacement motor. I couldn't find any 00 within eastern canada but I came up with a 03 with 219 000 km. Will this bolt and plug right in without any other mods? If I don't need a chip I'll try it without. Thanks.
Old 11-08-2009, 08:02 AM
Had a mechanic come over yesterday when I was pulling the engine. He took a quick look at it and said maybe to open it up before you get another motor. Then I showed him the plug and he changed his mind. The old plug isn't just broke, it is actually beat up pretty bad. The mechanic thought that the valve must have broke and then the plug got hit for it to look that bad. There was no compression on the cylinder at all. He took the gauge off just to see if there was any air coming out the hole at all. So Monday I will try to see if I can track down a power plant. Just need someone to tell me what is involved in th PI engine swap. Please? Thanks.
Old 11-08-2009, 08:26 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
simple process
remove complete NPI motor and install complete PI motor.
straight forward...
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 11-08-2009, 09:47 AM
Vehicle: 1998 ford f150
Quote:
Not to hijack the thread but I'm getting ready to replace my old 4.6 romeo as well (98 f-150). and not much luck finding one for under $1300 that runs, but I did find a 94 Lincoln Town Car with the 4.6 for $750, and from what information I can gather its a Romeo engine. My question being, even though they're both romeo engines some of the earlier production 4.6 had the old bellhousing pattern on the block I just cant remember what years. Also the tranny behind the lincoln 4.6 is the AODE I'm pretty sure, are their any differences between between the two engines as far as transmissoin issues go? Also some of the early modular engines had two bolt starters where as my 98 has three bolts. Just curious as to how one would identify if this engine would swap over. BTW I'm not concerned about intake issues with the blocks or pcm wiring etc, just wanting info on transmissoin bolt patterns. Thanks and sorry for the long post.
Old 11-08-2009, 09:52 AM
Vehicle: 2008 ford f150
Send a message via AIM to timmypstyle
Quote:
just to let you know that the 4.6 in the 94 crown vic was only rated at 190 or 195hp. so unless the truck's computer/exhaust/intake is better to up the HP, you will have a slightly lower power. my dad had a 94 crown vic, still have some power to them. they were rated 190 or 195HP and 265Lb-Ft in 94. cant remember exact HP but it is one or the other that i mentioned. other than that, i cant help you. i know car specs and stuff on paper but know very little about fixing stuff.
thanks to dirtyd88 for the sig
LOVIN THE HALOS!!!
BEST 1/4 MILE TIME SO FAR-16.9378@81.66mph
2008 F150 reg cab shortbed 2wd 4.2L V6 5spd manual 3.55LS rearend Hancook Dynapro AS 235-70-R17
MODS-K&N 77series CAI with helper tube from front bumper.
Old 11-08-2009, 05:43 PM
I read on an old post somewhere about a guy who was trying to get a 4.6 out of a crown vic to work 5 months after he started. The fuel lines were on the other side and some other things. It was about all the info I could find on anyone doing the swap. It would probably work but is more effort than I want to put into my daily driver. I pulled the valve pan today and didn't see anything suspicious. Is there a cheater way to get the crankshaft pulley off? I have a 3 jaw but I don't want to mangle it too much.
Old 11-08-2009, 06:20 PM
Vehicle: 1999 Ford F-150 5.4
borrow a pully puller from autozone...
Old 11-08-2009, 06:32 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Quote:
Well where do you live ? 5fours are everywhere in the colder climate states (allot of folks just can't drive in the winter lol), - there's alot of them around here, -complete set ups.
You gottuh keep your eyes peeled for those Saturns, they'll run right up Uranus...One got me, girl was okay, I was okay, the truck survived -to bad for her car tho.
Search this site with your ZIP, they'll locate one for yuh close to home. -
http://www.car-part.com/
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Ported & Polished Intake/TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Volant Intake w/Amsoil EEA191 Filter, 265/17 GY Fortera's.
Old 11-08-2009, 06:50 PM
BTW - You can correspond directly with a recycler from that site now. Nice addition!
Old 11-08-2009, 08:33 PM
I used mypartsshop.com to do my search. Probably the same deal. Here is the plug
http://www.f150online.com/forums/mem...3-img-0685.jpg
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
