F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 11-03-2009, 12:34 AM
2000 F250 5.4 No towing power????
I have a 2000 F250 4x4, automatic, with a 5.4 and i am completly disgusted with the amount of towing power or lack there of! However the truck is paid for and i am not going to jump back into payments as tempting as that sounds. The truck has 100,000 miles and i keep up with the maintenance very well, the truck has absoulutely no problems. So my question is what will give me the most bang for the buck as far as overall power for towing. I use the truck as my daily driver and use it to pull our 23' fifth wheel (very light) camper. Could i use a stock charger off of a lightning? would it bolt right up if so how hard would this be and what all would i need? any advice would be greatly appreciated!!!
Old 11-03-2009, 04:19 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
for routine hauling the charger may not be your best route but will definitely suffice.
hit ebay for parts, the intake "setup" complete from maf to lower manifold, with all the electrical should run you around $1400 USD. it varies as the supply changes.
then you have the other little things that add up super fast. check out www.madenterprise.com/
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 11-03-2009, 11:20 AM
Vehicle: 1999 Ford F-150 5.4
Gears maybe. I have 19 foot trailer that weighs about 5500 lbs and we have some mountains around here that are pretty hard for my truck to pull that trailer up. Sure wouldnt want anything bigger..
Old 11-03-2009, 01:39 PM
true, if he has stock 3.55's that would be a small issue. lots of guys like 4.10s and stock size tires for hauling.
Old 11-03-2009, 03:55 PM
Vehicle: 2003 Ford F150 FX4
Get a tuner (like the Edge) which has a canned tune for towing or better yet a tuner with custom tunes if you have any after market upgrades. There are a number of upgrades you can do to increase HP & torque - after market exhaust/high flow cats; cold air intake or stock intake mod; PCM tuner; supercharger ,etc. Depends on how much you want to spend. If you're running 3.55 gears, that would definitely make a difference on an F250, which is heavier than a F150 before you even hook up a trailer. If you're running tires anything bigger than stock and hauling a sizable load, bigger gears are almost a must have.
2003 FX4 Lariat SCrew, 5.4L, 3.73 Gears, 5" Rancho Lift & leveled, Edge Tuner, K&N CAI, MagnaFlow Cat-back Exhaust, American Racing 17x9 Alum. Rims, 35x12.5" ProComp Extreme A/T Tires
Old 11-03-2009, 08:40 PM
i have stock wheel and tire size will a tuner really have any effect? are 3.55 gears stock for a 4x4?
Old 11-03-2009, 08:55 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Quote:
I pull a car hauler with a 98 and haven't had a problem. No tuner, but it may not hurt in your case. I've tuned the trans w/hardware. I've been pulling full size handicap vans lately. Those are heavy for a half ton. Guess the biggest difference I noticed is when I updated the ignition 3 or 4 years ago. Hell, I'm over a quarter million miles on this one lol.
I would like to add a roots blower, just don't need it that bad
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Ported & Polished Intake/TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Volant Intake w/Amsoil EEA191 Filter, 265/17 GY Fortera's.
Old 11-03-2009, 10:07 PM
I have an edge/gryphon and it made it better but its still a dog going up those big hills out here. We do have some steep hill and its only bad for me on those. I80 Parleys summit I can only do 45 without the edge I was doing 40. I have the stock 3.55's to. I also have 32 inch tire the stock ones were 27 inches (about)
Old 11-03-2009, 10:33 PM
glc glc is offline
What's the axle code on your door jamb sticker?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 11-03-2009, 11:14 PM
Quote:
what numbers am i looking for? i see where it says axel...
Old 11-03-2009, 11:35 PM
H9 = 3.55 I believe.
Here's an 01 DJ sticker I got rid of because it couldn't pull what the 98 did, -it had a different trans -
Old 11-04-2009, 05:10 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
isn't there an exact same thread by this exact same guy in the supercharger section?????
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 11-04-2009, 05:23 PM
Could be , he just joined and has 5 posts, 3 of them here.
Old 11-04-2009, 08:50 PM
so sorry
Quote:
im sorry im new to the site and didnt know it was that big of a deal to post a thread in more than one section. just figured since the question was relevant to both sections i would post in both. sorry for any inconvenience that this has caused you
Old 11-04-2009, 08:52 PM
wish i could post a pic of mine but the are no codes where axel is written and it has not been rubbed off. any ideas as to why this would be
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
