P0102 indicates you have a fault with the MAF sensor. Inspect the wiring and connector. Reseat or repair if needed. Pull the sensor and inspect the filaments to see if either are broken.
Treat the MAF issue first as it is more critical and may be a contributing factor for both of the O2 sensor codes. A bad MAf will also cause the engine to fall flat on its face. With the power off, disconnect the MAF sensor and see if the engine runs more closely to normal (ignore the CEL that WILL result). If the engine runs well with no MAF in-circuit, then there is a fault with the MAF or its related circuitry.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
