Been doing a lot of searching on adding alcohol or something to that nature, to be a temporary fix to pass smog. Have a 2000 F1 4.6 that didn't pass smog. Running too rich. I desperately need this to pass so I'm looking into every option and came across the 99% alcohol in a 1/4 tank of gas idea. Does this really work? Can't afford to keep adding more $$$ into this thing thanks in advance guys
Alcohol will only help on a smog test if you have high Nox. It works by reducing combustion temps therefore the Nox. Nox is produced from high combustion temps because of lean burning and the cats not being able to handle the amount. I think yer sunk with trying any kinda additives to make it pass.
Responses to the question at hand is what I'm looking for. Thanks
when is the last time you performed any maintenance on your truck and what was done
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon) old albumshttp://www.f150online.com/galleries/....cfm?gnum=8805
Mods
K&N drop in
Nerf bars
Line-X Bedliner
BF Goodrich At KO 275/70/16
Upgraded back window to a slider
ScangaugeII
My gas saver is my 2001 Crown Vic p71
I try and do all the maintenance myself and replace or clean anything that needs to be done. It passed with flying colors last smog check (last year or so), but now it is running rich and couldn't figure out why.
I believe the sniffer. Got the print out after the test and they explained to me that it was running rich, and I believe it was getting too much fuel. Have the print out at home, will get those numbers asap.
That sounds weird. How does the truck run? Smooth and all? It seems odd it would fail without a CEL or poor running engine issues. I'd go ahead and clean the MAF make sure the air filters clean and all.
That's what im thinking too. The truck everything is running perfect and smooth. I replaced the IAC, cleaned the air filter, cleaned the TB, changed the oil, anything I could think of and it came back as a fail. No CEL, nothing out of the norm.
