Quote:
Originally Posted by DYNOTECH
Another thing to be aware of is on a truck engine the wide serpentine belt is used. If you get a Crown Vic or other car engine they use a narrow belt. Your current truck A/C, Alternator, P/S and all FEAD tensioners and pulleys are wide. You will just have to change out the frontcover pulleys and tensioner on the car engine to the wide truck design.
Not all trucks have the wider serpentine belt!
My 03 came stock with a 6 rib belt not an 8 rib belt.
Some have 6 and some have 8.
I think ford just put on whatever they had the most of.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
