So a while ago i decided i was gonna drop the fivefour and put in a LS6 . Easy to make power on. 1 Cam, Good flowing heads, Aftermarket is dirty stupid cheap, and i like to be original. I think ima go TH350. I got my Friend welding everything up. Just waiting on the Trans and Motor to be finished so we can start fabbing up the stuff
GL with the install gonna be pretty cool once its all done, should be pretty quick.
2005 ford f-150 XLT Screw 4x4 2.5" leveling kit 20" platinum rims with 35" toyo m/ts full 3 inch exhaust with twister muffler. Pioneer Avic-D1 type R components and 2 12" kicker cvr subs and many other things
We are gonna run a stand alone engine management, i think we are gonna keep the C.O.P set up and run a Speed density set up. The bottom end is Manley Pistons with Manley rods. Manley Timing Chain. Manley Pushrods. it has a 236/242 cam. I have ported and Polished Heads with ARP Head studs, Dual Valve springs. Nitrous kit should be in soon, 150 shot with a progressive kit to get the second stage going. hoping for 250 in total.
Quote:
Too bad you can't wait - I think the new 6.2L Boss engine is going to be the engine you wish you had in your truck!
Ford is gonna want stupid money for that motor. maybe around 3-4 thousand for the long block with sensor and without harness. I got everything i needed motor and trans and Harness for $1500. I could have kept it stock. there good for 600hp. But since it was out. I just 2k into the motor, and i am where i am now. truck should make 400-430 on the motor. maybe 600-650 on the nitrous. 11:1 compression, big cam, and alot of Nitrous is the way im doing this.
Quote:
awesome!
an LS6 powered F150!!
GL im interested to see what issues you run into during the install
It shouldn't be bad. we looked at it. the way the LSx series motors sit. they sit pretty easy for fabbing. the driveshaft is where i have to get creative.
thanks, i hope it is. If not...... I'ma spray and pray the Piss out of it til it blows
You can't honestly wannna put a chevy motor in a Ford? There is a reason they're as cheap as they are!LOL Anyway good luck with it...hope ya get it all worked out!
Your not the first guy to put chevy junk in his ford. There are LOTS of Ford options that really wouldnt have been that much more. 351 windsors are plentiful and cheap, Weak.. Should have just started out with a chevy.
