F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 10-20-2009, 08:18 PM
Vehicle: 2002 Ford F150
99 Intake on 02 5.4?
Well I am replacing the intake on my truck since the plastic is cracked on one of the runners. I have a friend that has a metal intake off a 99 with a 5.4. Since the 99's had PI heads I assume this intake will fit on my 02 with no issues? Just looking to put a stronger intake on it since I'm running a procharger setup.
Old 10-20-2009, 08:35 PM
Vehicle: 2000 Ford F150
I'm pretty sure only the late 99's had PI heads. Also mines a Dec of 99 build date, but considered a 2000 and I have the plastic intake as well. So I'm not entirely sure the metal intake manifold was available for PI heads.
If there is a metal intake manifold for PI heads, I can't see why there would be an issue mounting it to another PI motor. Just take a look at the intake ports. If they match then you should be good.
- Erik
Old 10-20-2009, 08:40 PM
Vehicle: 1993 ford f150 xlt
almost all 99 5.4's had pi heads. there may have been a few npi's early in 99 but i've never heard of one in a 99 yet. the aluminum intake will work just fine.
Old 10-20-2009, 09:04 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
The 99 engine in my truck has Pi heads. You should be fine.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 10-20-2009, 10:05 PM
Awesome, thanks guys
Old 10-20-2009, 10:50 PM
Vehicle: 1999 Ford Expy/SCREW
The aluminum intakes have a much different gasket under the throttle body.
I have both intakes in a '99 and '01 and '02. Went to clean the TB and had to get different gaskets. The plastic one uses a rubber band type while the aluminum uses traditional.
Old 10-20-2009, 11:02 PM
Yeah I figured that, thanks for the heads up though.
Old 10-21-2009, 04:32 PM
Send a message via MSN to Gotts2BMe
Quote:
There were zero 99 f150's with npi heads. The left over 5.4's with the npi heads were used in the superduties till they were all used up
Gotts Intake with K&N - OBX Long Tube Headers - Magnaflow 15749 - DIY Efans - MAC UDP's - Troyer Tunes - 75m TB - Ported intake - 33" Firestone Destination M/Ts
220,000+ Miles
Old 10-21-2009, 05:04 PM
Vehicle: 1998 Ford F150 4x4 5.4L
99 F250's w/5.4's didn't have PI heads, just the 1/2 tons. That's all you have to worry about when looking for used heads and engines.
Neither did the E models.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
