F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 10-20-2009, 07:17 PM
Vehicle: 2001 Ford F150 4.6
Send a message via AIM to alex7191
Truck sort of eases into being started?
Most of the time when i start my truck it doesn't start normal and healthy. The RPMs dont jump up then go down like it should. the RPMS raise up slow and it starts slow and rough.
But, if i leave the key in the ON position for a few seconds, then start it, it makes an explosive big normal healthy start. But if i dont, it sort of eases into the start with the rpms low and it shakes the truck.
any ideas?
i just replaced the fuel filter within less than a year. and put all new plugs and COPS in it within the last six months.
01 4.6 with 180k on the clock
'01 XLT 4.6 3.55LS
Reg cab / long bed :)
True dual Flowmaster 40s dumped| Gotts mod intake
Old 10-20-2009, 07:35 PM
Vehicle: 1999 Ford F-150 5.4
.Clean the throttle body and MAF
Old 10-20-2009, 07:41 PM
Thanks. Ill do that. Figured i should but didnt want to mess with it if it wasnt messed up.
forgot, i've cleaned the MAF within less than a year. Hopefully i can find that can of cleaner.
'01 XLT 4.6 3.55LS
Old 10-20-2009, 08:00 PM
follow these instructions
http://www.fordf150.net/howto/throttlebodyclean.php
http://www.fordf150.net/howto/clean-...low-sensor.php
Old 10-21-2009, 12:50 AM
Vehicle: 1998 FORD F 150
When was the fuel filter changed last?
Old 10-21-2009, 03:33 AM
in the last 6 months
'01 XLT 4.6 3.55LS
Old 10-21-2009, 06:24 PM
Vehicle: 2003 Ford F150 FX4
Thinking there's might be a possible issue with the fuel pump/fuel delivery since you said if you leave the key on for a few seconds before you crank will fire right up. But definitely do all the cleaning items first whenever there's an issue. Replacing the fuel filter is based on miles, not time so if there's a lot of miles on that fuel filter or you suspect you may have gotten some dirty fuel, wouldn't be a bad idea to replace that if the cleanings don't fix the problem.
2003 FX4 Lariat SCrew, 5.4L, 3.73 Gears, 5" Rancho Lift & leveled, Edge Tuner, K&N CAI, MagnaFlow Cat-back Exhaust, American Racing 17x9 Alum. Rims, 35x12.5" ProComp Extreme A/T Tires
Old 10-21-2009, 07:56 PM
Quote:
yeah thats what im really hoping is not the problem.
im going to try to clean the throttle body tomorrow. also clean the IAC and MAF while im in there
Old 10-21-2009, 09:18 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Change your FP relay.
Old 10-22-2009, 02:30 AM
Quote:
that will be my next step! hopefully i wont have to go that far.
is there some sort of coolant line ill have to mess with to take the throttle body off?
Old 10-22-2009, 03:03 AM
glc glc is offline
FP relay is cheap and simple to change.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-22-2009, 04:48 PM
The TB is easy to get off and there's only 2 cables connected to it. The intake manifold (where the coolant line connects to) is another story (at least on the 5.4). When you pull off that coolant line, make sure the engine has cooled down so you can relieve any pressure from the radiator (unscrew the cap on the fill tank after it's cooled down) so when you disconnect the lines to the intake manifold it doesn't get all over the place.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
