F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 10-15-2009, 12:18 PM
Vehicle: 1997 Ford F-150
Problems With a 97 4.6L
My truck seems to be missing and lack of power. Im coming up with codes P0301 (cyl misfire#1) and P0307 (cyl misfire#7) and P0171 (bank 1 lean) and P0174 (bank 2 lean). ANy ideas on where i should start? The plugs/wires and fuel filter where just replaced. Thanks in advance guys!!
Old 10-15-2009, 12:49 PM
Vehicle: 2000 Ford F150 7700
Quote:
how many miles and what kind of plugs?
Old 10-15-2009, 03:59 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Yea , coils as well. A 97 w/miles, it may be time to go thru everything.
Old 10-16-2009, 01:40 PM
Its got bosch platnums and the trucks got 271,000miles. I just replaced both coils and the only code im coming up with now is bank 2 lean. I wonder if one of my cats is plugged? Its running on all 8 but still dont have much power... thanks guys...
Old 10-16-2009, 02:17 PM
glc glc is offline
Vehicle: 2003 Ford F150
Get those Bosch out of there and put Motorcrafts in. Check the PCV elbow in back of the intake manifold for cracks and mushiness.
A muffler shop can use an infrared sensor to tell if your cats are clogged.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-19-2009, 03:15 PM
Vehicle: 1997 ford F150 4.6cc
hey
Yes GLC , i had the same prob only i also had code p1409 ( snap on tester ) and today i checkt all the vac hoses and no crack in it . So i have disconected all the vac hoses and also the demounted the right innerwing . There is the canister with the vac hoses . then i disconected those and cleand eatch off it with air pessure . The hose from the canister to the EVR was as good as closed and i blow all the dirt out of it . by remounting everything the prob was fixt , no more lamda probs and no more evr code .
hope its a little help .
Is it not so GLC when the cat is blocked that the hoses DPFE and EMS has to blow of from the egr tube ?
Cya
Old 10-19-2009, 05:19 PM
Vehicle: 1997 ford f-150
Send a message via AIM to shifty_85 Send a message via MSN to shifty_85
Get the bosch plugs outta there and get ya some motorcraft plugs ASAP that will help the misfires.
as for the lean check vac hoses and the intake manifold for leaks.
Old 10-19-2009, 06:17 PM
Vehicle: 1999 Ford F-150 5.4
Bosch plugs dont do well in modulars probably the worst plug for them and they are picky engines that way. Get Motorcraft Denso or NGK plugs.
Old 10-26-2009, 11:54 AM
Truck runs good now! #7 injector was bad, #1 cyl the coil was bad, 2 of the cats were plugged and there was a vaccum hose cracked by the passenger side valve cover. Replaced injector, took all 4 cats off and welded bungs for o2s in new pipes, replaced vaccum line and replaced both coil packs. Thanks guys!
Old 10-26-2009, 05:18 PM
glc glc is offline
You should really put 2 high flow cats back on.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
