F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 10-11-2009, 01:24 PM
no spark no fuel pump...help
i got a 2000 f150 and we pulled the motor and dash apart to do some work to it...hooked it all back up and it cranks overs but the fuel pump isnt turning on and we are getting no spark...fuel is at the rails and the pcm is sending signal to the fuel pump relay...it has the stupid PATS system in it...we are about to give up and drop in a 351 or ls1 ...it is a offroad dezert race truck by the way..
Old 10-11-2009, 02:49 PM
glc glc is offline
Vehicle: 2003 Ford F150
Have you checked the inertia switch?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-11-2009, 03:06 PM
its a 5.4l forgot to mention....where is the intertia switch located exactly?...
Old 10-11-2009, 03:44 PM
Vehicle: 2002 Ford Expedition
Are you sure the pump isn't getting powered? It will only power up very briefly when the key is in the on position when the engine isn't running. So when you troubleshoot it, you have to be right there at the connector to test for power when someone first turns the key on or while the engine is cranking.
If you have fuel at the rail, I would think your pump is working.
Old 10-11-2009, 06:41 PM
Vehicle: 1998 FORD F 150
Quote:
Behind the kick panel, passenger side....it is easily removable.
Old 10-11-2009, 08:30 PM
Vehicle: 1997 Ford F150 5.4
What is the THEFT light doing?
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 10-12-2009, 09:13 AM
ok got the truck to turn on but it wont stay running....we had a bad relay a bad pcm and a ground was bad to the instrument cluster...should be ready to go today
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
