F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 10-04-2009, 05:31 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Quote:
Originally Posted by daves03 View Post
I can verify ford using an impact to put on the oil filter at the factory. I work at NTB and did an oil change for a guy with an 09 Expedtion. It took alot to get this filter off. Never again, took me 15 min to get this dang filter off.
They use an Impact lol ? Or was that a figure of speech ? Yea, I know their a PITA first time around.
Old 10-04-2009, 05:43 PM
Vehicle: 2005 Ford F150
Impacts are not used to install the oil filter at the engine plant, as you can see by the photo below of the filter installer.
Old 10-04-2009, 06:00 PM
glc glc is offline
Vehicle: 2003 Ford F150
Darren, nobody is saying that synthetic is not safe - they are just saying it's not necessary and it's going to cost you more.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-04-2009, 06:27 PM
They only time going Fully Synthetic can be dangerous is when upgrading in higher mileage engines.
Engines brought up on Mineral and Semi-synthetic grades can have a certain amount of sludge build up in crankcase and elsewhere. Full Synthetic has a higher cleaning attribute which may break to much free at one time compromising other internal areas.
You can still switch,- if you feel the need, but you should flush the crank-case first.
It's allot easier and cheaper sticking with the recommended Motorcraft oil IMO. She's plenty protected
Old 10-04-2009, 09:35 PM
Mobil 1 will be used on the first oil change.
Old 10-04-2009, 10:12 PM
Vehicle: 2002 Ford F150
Send a message via AIM to f150fella08
i find it easy to get the first filter off, take a 3/8" ratchet, about a 12" extension, and a oil filter tool called a spider http://ultralightsparkplugs.com/prod.../11/2507-1.jpg
True Dual Straights, No Mufflers, H Pipe, Maggie Hi Flows (94106) http://www.youtube.com/watch?v=vt6qpxghCwQ
Old 10-04-2009, 11:03 PM
Quote:
Good luck with that, -To much bologna and controversy from the past for that manufacturer, -that would make Mobil 1 the worst possible choice IMO. Their oil has tested bad, that might not be the oil your purchasing, but it's a the simple fact that some of their oil has. I wouldn't chance a $30,000 (or so) investment on it, - specially when there's no reason for it.
You going to run Fram filters as well?
Old 10-05-2009, 12:45 AM
Vehicle: 1998 Ford Expy 5.4
Send a message via AIM to Camarothatcould
fram ftw
the Lead sled
Swapped 5.4. . . cause 4.6's are only good for taxi's and boat anchors. . .
Old 10-05-2009, 01:38 AM
Vehicle: 2004 Ford F150
Send a message via AIM to IR0NS1N Send a message via MSN to IR0NS1N
Quote:
Originally Posted by Camarothatcould View Post
fram ftw
Fram FTL big time. WiX FTW!!!! and either redline or amsoil 0-20 or 5-20 full synthetic FTW.
Old 10-05-2009, 02:06 AM
glc glc is offline
The Mobil 1 EP is a quality oil - the only Mobil 1 that's under question is the standard grade 5W30.
The GP 3 synthetics don't cause problems in high mileage engines - its the PAO's. Those you have to be careful with.
Old 10-05-2009, 07:39 AM
Vehicle: 2001 Ford F150
Make sure it is the EP version. If not skip it and use the Motorcraft blend and save some cash.
Old 10-06-2009, 02:17 PM
Vehicle: 2007 FX4
Quote:
Originally Posted by glc View Post
BS. You can use full synthetic as long as it meets Ford specs. 5W20 is the correct grade. However, don't switch to it till your SECOND oil change. Have the DEALER do the first change with standard Motorcraft 5W20 semi-synthetic, then after that, do what you want. Reason for having the dealer do the first change? Ford uses some gorilla named Bubba with an impact wrench to screw the oil filters on at the factory. It's very difficult to remove.
There's no need to wait until the second change to switch to synthetic. I switched mine at 500 miles and have had no troubles out of her. Now that may have been true back in the day when it took a while for engines to break in, but todays engines are pretty much set from the factory.
Old 10-06-2009, 03:32 PM
glc glc is offline
That's not the reason I suggested to wait till the 2nd change - the reason is that you should use the dealer for the first change due to the filter issue. No reason to try to get the dealer to use anything but their standard oil.
Old 10-06-2009, 03:54 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Thanks for clearing things up for me guys
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Painted Headlamps/Fog lamps, 20% Tint
Performance: PHP Gryphon 87 Perf, 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks, 20x9 XD Monsters, 33x12.5 Toyo M/Ts
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone Tunnel Carwash Rev
Old 10-06-2009, 06:16 PM
Vehicle: 2007 FX4
Ah ok, my mistake. I bet they don't put oil on the filter gasket, its not that they crank it down-its just on there dry.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
