F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 09-28-2009, 07:33 PM
what octane fuel should i use?
i have a 2004 4.6L 8 cylinder and I've been using 87 fuel. should i upgrade to 89 or even 91 when filling up the tank? would i see any improvements by doing this?
Old 09-28-2009, 07:45 PM
Vehicle: 2002 Ford F150
Send a message via AIM to f150fella08
Quote:
ive never noticed any, whats wrong with using the recommended octane the owners manual says to use? all i know is ive seen a good improvement since i stopped using fuel with ethanol
Old 09-28-2009, 07:52 PM
Vehicle: 2006 Ford F150 XLT
It will only slightly improve mileage and depending on the brand, might make it slightly cleaner. You can only take full advantage of the higher octane fuels with a programmer.
2006 Ford F150 XLT - 281ci V8 - Regular Cab/Flareside - 2WD
True Dual Magnapack Exhaust - Gott's CAI - Edge Evolution Programmer
Mustang Exhaust Exhaust Interior Drive By
Old 09-28-2009, 08:12 PM
Vehicle: 1999 Ford 5.4L F150 4x4
There's no advantage to using higher octane fuels unless your have pinging or custom tunes...
| PI Heads | Platinum & Amsoil | ScanGauge II | Factory Tech Sep. Plate |
| BBK UD Pulleys | AF1 w/ ram air & heatshield | deleted rear cats |
| mandrel bent true dual straight pipes w/ H-pipe | 3.5 x 18" rolled Silverline tips |
Old 09-28-2009, 09:14 PM
glc glc is online now
Vehicle: 2003 Ford F150
If you have a knock sensor, you may notice a slight improvement in performance and economy, but not worth the extra cost.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 09-28-2009, 10:58 PM
Vehicle: 2005 Ford F150
use the octane that your tune calls for. Stock, 87.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 09-29-2009, 11:19 AM
Vehicle: 2000 Ford F150 7700
Quote:
x2.
Old 09-30-2009, 10:50 AM
Vehicle: 1999 Ford F150 4X4
Up here in my area the 89 octane is 5 cents cheaper and that is why I use it!
Jeff Sedler
'99 150 4x4
4.6, Hurst 5-spd
Retrax Bed Cover
SuperCab XLT
Old 09-30-2009, 11:20 AM
If you have no custom tunes and your engine is not knocking, stick with 87 But I would do my best to stay away from any gas that has ethanol in it. As it will cause your mpg to go down and may cause some loss in power.
Fabtech 6" Suspension Lift
3" Body Lift, 38X15.5X18 Tires
4.56 gears, Full Size Spare Tire.
Old 09-30-2009, 02:00 PM
Quote:
That's because your 89 is really 87 with the addition of 10% ethanol. If you are okay with the 10% less gas mileage, go for it.
Old 10-19-2009, 10:33 PM
I lose at least 10% with ethanol blend (89 octane). At $2.50 a gallon, 89 would have to be at least $.25 a gallon cheaper to break even. Ethanol should not be used in motor vehicles, it is not clean, green, or efficient.
Old 10-19-2009, 11:33 PM
Where does a guy in Southwest florida find non ethanol Fuel? Lee
Old 10-20-2009, 06:21 PM
Vehicle: 2007 Ford F150
Gas
You want to try and find non-alcohol added gas here, I don't think it's possible without going to either av-gas or racing-gas. I think it was mandated that all gas have alcohol in it to help the farmers and alcohol plants. In all the years I've lived here, other than racing fuel, I don't remember seeing any gas without alcohol it in, like it or not.
Old 10-21-2009, 07:43 AM
Vehicle: 2001 Ford F150
Almost all gas has up to 10% ethanol now as it has replaced MTBE. This was done because MTBE was being found in wells and ground water. This was not done to sell corn.
My mileage has not suffered from the 10% blends up here in New England.
01 Black XLT 4x2 Screw Gen I, 5.4, Moonroof, 3.55LS, Cloth Captains, Slider, Extender, ClassIII towing, Stull Billet Grill, Line-X, New back up lights so I can actually see something! Lightning Third Brake light and tails, Weathertech window visors. Billet AC Knobs, Bilstein shocks, Mag-Hytec Differential Cover, Amsoil, Superchip Tuner,
Rocking to Adire Koda 6.1 speakers, Polk dx10 sub in Subbox.net box and Kicker kx700.5 amp. Kenwood DPX-701 headunit and Sirius tuner.
Old 10-21-2009, 08:59 AM
Vehicle: 2004 Ford F-150
Quote:
I have looked and looked for the past year of two since we have had it all over. None that I have seen but I mainly stick to the same stations. At one point in time the Hess "I think it is" on US 41, just south of Cypress Lake/Daniels had it on the west side fo the road. Acorss the entrance to Barnes and Noble.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
