Any experience with a remanufactured PCM?
(I posted this question in another thread, but then thought it made sense to post it as a stand-alone question. Sorry about the duplication, but here goes):
Has anyone ever installed a remanufactured PCM (Powertrain Control Module) computer? I've checked with 3 parts stores (Auto Zoo, Advance, and O'Reillys), they all carry the same brand, A1/Cardone, and all say it will take about a week to get one flashed and shipped here to Austin, TX. The cost is pretty reasonable at all 3 ($150-$200).
I was just wondering if anyone had ever installed one of these rebuilt PCMs and how it worked out for them?
Thanks,
Ron
Edit - this question was originally posted in the following thread:
https://www.f150online.com/forums/v8...k-bad-pcm.html
Thanks,
Ron
For Dyno testing at Ford's we used vehicle pcm's that had to be reflashed many times in order to tweak performance. Some of these were 15 years old and older as we also dyno tested early model remanufactured engines for engine reman companies. They took a beating, dropped, high heat, coolant and gas spraying on them you name it and they still usually worked. It's a crap shoot with electronics as you could get a good or a bad one but that also goes for a brand new component of any kind. What sort of warranty do they offer? I mean if you stick it in and the truck runs like crap will they reflash without an additional charge. Ask some questions on how they guarantee their product. Good luck.
DYNOTECH - Excellent suggestion! These PCMs come with a 1 year warranty, but I have no idea if that covers additional flashing. I was told that before shipping, they're flashed at the factory according to the calibration number and/or VIN from the truck. Neither the engine nor the PCM on my truck have ever been modified, so I'm assuming that a factory calibration flash would be equivalent to what it's running now (is that an accurate assumption)?
I will now certainly be asking some questions if and before I order.
Thanks,
Ron
Thanks,
Ron
Thanks,
Ron
Thanks,
Ron
