F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 07-04-2009, 03:44 AM
Exclamation truck will not start at hot temperatures
I have a 1997 ford f150 4.6 2wd. It appears to not start at temperature over 80 degrees. If I take off the fuel cap and let it sit for a while it will start. The fuel pressure is with in specs. It is about 32 psi on idle it jumps to about 40 when vacuum is disconnected also it holds pressure after it is shut off quite well. There is a tsb about the same problem, it has to do with winter blend fuels but it did not solve my problem. The truck has not DTCs and the fuel filter was just replaced by myself. I think it might have to do with the fuel pressure sensor or maby with the evap.
Old 07-04-2009, 09:36 AM
Vehicle: 03 4X4 5.4 SCREW
Have you checked the fuel pressure when trying to crank the motor over 80 degrees?
Old 07-11-2009, 09:00 PM
yes it is zero, it took a while because it was a bout 60 all week.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
