Quarts of Oil in a 2004 5.4 ??
Old 02-25-2009, 11:43 PM
Mike_fx4's Avatar
I have a 2004 fx4 5.4 f150, Does anyone know how many quarts of oil it holds on a oil change ?? thanks
Old 02-25-2009, 11:44 PM
Hespen537's Avatar
6 Quarts. =)
Old 02-25-2009, 11:45 PM
Hespen537's Avatar
Scratch. It'd probably closer to 6.5 after you fill the oil filter. Guess the manual doesn't tell you that.
Old 02-25-2009, 11:53 PM
Mike_fx4's Avatar
Sounds good ! thanks! What is a good motorcraft oil and filter to run? I have a fram filter on it right now from when i bought it and it doesnt hold good oil pressure with it
Old 02-25-2009, 11:55 PM
7 quarts.
Old 02-26-2009, 03:01 AM
code58's Avatar
Hespen- Have you actually read your owners manual? And do you have a 4.6 in the '07 that your profile shows? Like Bluejay said, '04-up 5.4 3V takes 7 qts. They took 6 qts. in the 5.4 up through '03 and the '04 Heritage 2V but the 5.4 3V has always taken 7 qts. with filter change. That brings it to half way between the marks on the stick, which is where it belongs.
Old 02-26-2009, 03:13 AM
code58's Avatar
For 1 thing I wouldn't run a Fram filter on a goat cart much less on a truck that sold for over 30k new. You say it doesn't hold good oil pressure with the Fram. I hate to tell you this but the oil pressure gauge Ford has used for quite a while is a idiot light with a needle, meaning it does not reflect actual oil pressure. Does yours move or just stay in one spot? That is a criminal act on Ford's part I believe but they decided in their almighty wisdom some years agp that people would be happy if they thought they had good oil pressure so the put a phony gauge in that only shows if you have oil pressure or none. My oil pressure gauge stays the same if I'm idling on a hot day or running 80MPH. It's only a "feel good" gauge. If yours is actually moving (reflecting actual pressure) or running low pressure, something is strange because Ford didn't build it that way.
Old 02-26-2009, 03:23 AM
Like the guys above posted "7" quarts for the ThreeV's.
The TwoV's are 6 including filter. The only time you add more than 6 is if the truck has an oversized filter (after market) or the truck has a remote system that has been disassembled/reassembled. That said, the extra amount needed to bring it up half way on the stick(that's full) after reassembly doesn't even amount to a 1/2 quart. A simple two valve oil change, with remote system or without is 6 quarts.
The following users liked this post:
Old 02-26-2009, 09:23 AM
06 So Comfort's Avatar
You can't go wrong sticking with what the owner's manual suggests:
Motorcraft 5w20 Syn Blend and Motorcraft 820S filter.
Old 02-26-2009, 09:24 AM
last5oh_302's Avatar
6.6 litres, eh.
Old 02-26-2009, 08:04 PM
Hespen537's Avatar
7 Quarts always over fills mine. And thats with the 5.4L Yea, man. says 7 Only thing is, its always over. Im pretty sure my 5.4L is the same as any. Either that or I must have some type of spacer in my oil pain that over fills me at 7. You tell me.
Old 02-26-2009, 08:08 PM
7 quarts (6.6 litres) puts me at exactly half way in the cross hatched area of the dipstick, right where it's supposed to be. My newest two other Ford vehicles which were/are cars, are exactly the same. Half way in the cross hatched area when using the specified amount of oil.
Old 02-26-2009, 08:18 PM
wreedKR's Avatar
My 07 takes 7 quarts.
Old 02-26-2009, 10:26 PM
F150+Bronco=ME's Avatar
new bodys take 7 quarts
Old 02-27-2009, 03:09 AM
04ScrewFX4X4's Avatar
6 3/4
I see most people say 7, I have always put in 6 3/4 quarts, then after 500 or so miles I check again if it needs a little top off I have the 1/4 quart left for that. I run Mobile 1 5w20 sythetic, so yeah its not a cheap oil change.
Quick Reply: Quarts of Oil in a 2004 5.4 ??
