Engine skip/bucking
Old 01-28-2009, 03:36 PM
wreedKR's Avatar
i used it on my chevy 350, did i screw up by doing that?
Old 01-28-2009, 03:44 PM
shroville's Avatar
no dont use it on the 2v ford engine only, anything else should be alright
Old 06-19-2009, 06:50 AM
Brin Brin's Avatar
2002 ford f150 4.6l v8 cylinder 5 low on compression
Started truck on morning, service engine light came on, engine started running a little rough and missing, some power drain. 71,000 miles on engine. Changed fuel filter, didn't fix, took it to a local shop, they checked cylinder 5 based on p305, said it was low on compression, suggested rebuilding the engine. I checked it on on the web. Found identical problem that i was having and the suggestion was to change spark plugs and coil pack. Called the mechanic back, he said it wouldn't make a difference when it comes to compression. I went somewhere else, changed coil pack and spark plugs. Fixed problem. The bill went from $2,000 to $146.00.
Old 06-19-2009, 08:32 AM
jbrew's Avatar
Well, someone was wrong
Old 06-19-2009, 12:16 PM
glc is offline
If the compression is low, expect the plug and coil to be a temporary fix.
Old 06-19-2009, 12:59 PM
jbrew's Avatar
If you have a print-out of what they found to determine. We could tell yuh.
A read of all eight would be best, but if you have the numbers for just one,- depending on what it is, we might be able help.
Old 06-22-2009, 07:19 AM
Brin Brin's Avatar
Your right. We checked compression again and there was plenty of compression to make the cylinder fire. Maybe the other guys instrument was off?
Old 06-22-2009, 07:23 AM
Brin Brin's Avatar
We cross-checked with the other cylinders (even after we checked the compression on the cylinder that was "low" on compression and found out it wasn't) and everything checked out. I didn't realize each engine kind of has it's own compression "signature". Thanks.
Old 06-22-2009, 09:14 AM
jbrew's Avatar
Here's a general -
http://www.aa1car.com/library/compression.htm
Test warm if possible, - more accurate.
Old 06-22-2009, 04:56 PM
tjk_in_cny's Avatar
Here's a general -
ANOTHER GREAT ARTICLE SAVED TO MY REPAIR FOLDERS.....
Good Job, Thanks....
Old 06-22-2009, 05:03 PM
jbrew's Avatar
Yea, I didn't feel like writing, so I opened another browser and googled it.
Hey!- it's right, even the #'s.
______________________________
Damn!!! That is a good link!! I went back
Old 06-22-2009, 10:44 PM
tjk_in_cny's Avatar
Damn!!! That is a good link!! I went back [/QUOTE]
You kill me
How you been man. Going on Vacation starting Sat. I'll have my son's laptop with me so I can check in now and then. Behave yourself while I'm gone !
Quick Reply: Engine skip/bucking
