Mine won't start after changing battery
Both fuses were in working order. Took a better look at the starter. Started to move wires around, and the main wire to the starter from battery fell away from the starter. I fixed that with new cable end cleaned everything off put everything back, and presto changeo, it did not work.
I guess it is the cellenoid, or the bendix. I do not know how hard it is to change that.
Guess it will go to the shop, just hate to have to,,, have it towed,
Thanks for your help
I don't know if you can buy them separtely anymore. Anyway's, RockAuto.com has them starting @ $89.00 for a new one.
http://www.rockauto.com/catalog/x,ca...,parttype,4152
I used my truck year but the above link will give you a good idea of what you will pay.
I just put a new Beck/Arnley starter motor in for $140.00 from Advanced Auto Parts with a lifetime warranty and did the whole job in 2 1/2 hours. That includes pulling the passanger tire off for easy access to the top and side bolt's on the starter. If you do the work yourself, make sure you use anti-seize on the 3 bolts before you put them back in.
picture of starter
Thanks for the great picture. The braded wire coming from the cellinoid and going into the starter. This wire on mine is completely wiped out. I could barely make out that it was once a wire at all, until I reached in and pinched it between my fingers, and brought it out to see little peices of wire.
Seeing as how I am in no great big hurry for the truck, I think I will go ahead and put in a new starter. So just putting on a new cellinoid is out? I use to put them on my cars back in the 70's, with great success but that was a chevy. And there were no computer on board then either. I see two bolts to get the starter off, is this correct? Thanks again.
There's 3 bolts, that braided wire runs from the solenoid to the top post , like this -
Sounds like your wires are all deteriorated. If the braided wire is still connected to solenoid and IF you can manage to loosen the nuts where the other wires connect, you may be able to save it.
Chances are, it's to far gone - soon as you stick a 10mm on that little nut, you'll break the post off.
There easy to change as TjK explains.
Seeing as how I am in no great big hurry for the truck, I think I will go ahead and put in a new starter. So just putting on a new cellinoid is out?Years ago, i would just put the solenoid on as well, but I don't think you can just buy the solenoid anymore. I did some checking on the internet for you and found nothing. When I googled in starter solenoid, it directed me to the STARTER RELAY which is on the firewall next to the 175 amp fusable links. I use to put them on my cars back in the 70's, with great success but that was a chevy. And there were no computer on board then either. I see two bolts to get the starter off, is this correct?I know you have a 4.6L but I can't imagine 2 bolts are holding your starter in. If it is the same setup as mine and Brew's 5.4L's, As I explained before, pull the front passanger tire and you will see 1 bolt on top at 12 o'clock position. 2nd bolt @ 9 o'clock position and from underneath the truck you will have your 3rd bolt at about the 5 o'clock position. Thanks again.
I can't find the link, as I thought I had it bookmarked. But you can download the owners manual for free. Just do a search for the right one.
This is what I get when I put the part number you gave 1M1090.
http://www.rockauto.com/catalog/catalog.php
Here is a pic of it
http://info.rockauto.com/Airtex/Detail.html?1M1090.jpg
Be sure your buying the right part.
Here is a pic of it
I have only found the one I listed, I see now that it was the one for the fire wall.
Jbrew did you say you found the one for the solenoid? If so could you post the part
number and company from which it belongs?
Plus, I was also thinking, that it looks like the braided wire that disentigrated on, is part
of the starter. So I guess if I get a new solenoid I will still not have the wire coming from the starter. Maybe I could go into the starter, attach a new solid wire ( because I would know where to get a braided one) and wire it to my present solenoid, and not have to buy anything.
Now stop staring at your truck and get it done. I still need pic's of your intake assembly.
