F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 11-18-2008, 08:09 PM
Vehicle: 2001 Ford F-150
No high idle when cold no codes need help!
My 2001 5.4 supercrew will not hold a high idle when its cold .i have to hold down the gas pedal to have the engine run. What is causing this? Coolant sensor, tbs. The funny thing is i am getting no codes. When engine is warm it idles but only at 500 rpm. Need help!!!!!
Old 11-18-2008, 08:10 PM
Vehicle: 1993 ford f150 xlt
most likely the iac.
Old 11-18-2008, 08:19 PM
this sensor is on the air tube?
Old 11-18-2008, 08:35 PM
Quote:
the iac valve is on the back of the 90* elbow that the throttle body mounts onto.
Old 11-19-2008, 09:20 PM
to fix should i spray throttle body cleaner in it?
Old 11-20-2008, 05:34 PM
your better off taking it off if your gonna clean it. but you'll most likely need to replace it if it is bad. and if you replace it you may want to consider cleaning the throttle body while your at it if its never been done.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
