How to take off tensioner pulley?
I wasn't sure if the Sohc (2 valve) 5fours had something there. ?? I just noticed this
Thanks Neal. I'll get another - I hope new ones come with a freakin bolt
I don't want to go with efans on this truck right now, but I did notice a difference when i fired it up without the belt -Quite a bit snappier when cracking the throttle. Think a new AC clutch would help ? - Just want everything to spin at it's best without an efan install.
I hope I cane get that belt on w/that second pulley.. It's going to be close.
Nice Engine - Great pics!
Some info -
Nice write up on the Tensioner (From Gates Corp.)
http://www.gates.com/file_display_co...3%2D0796%2Epdf
Another from Dayco -
http://info.rockauto.com/Dayco/TensionerTip.html
ROCKAUTO is my new favorite, at least they have a selection to choose from and the right pics to go with their products -
http://www.rockauto.com/catalog/raframecatalog.php
Found some at Summit that look better, I think I'll order, not much choice on the 98, but they carry AC Clutches as well - I want to replace everything up front - To many miles - I'll be needing the truck again after the first of the year to pull 3500-4000 lbs across a few states - preventive maintenance ..
Maybe I start my own thread ? - Sorry *****, don't mean to steel yours..
Summits stuff -
http://store.summitracing.com/partde...677+4294840115
http://store.summitracing.com/partde...=1#Application
Summits stuff -
Your confusing me - Tensioner pulley is called that. Idler pulley is separate unless your talking about another vehicle , not a truck/ford..? Unless you are talking about the same thing and was just pulleys ? That would just cause more drag and kill some of your power - Wouldn't advise. - Pulleys are sized in accordance too ..
BTW- Why do you say the pulley goes on backwards to be right ? There's only one way that's right - Backwards isn't right ? I'm confused again.
while i had the tensioner assembly off, what was the front of the assembly, seemed like you would put the pulley facing foward on it, instead it goes on "backwards". i guess you would have to pull it off to understand. either way, be sure to look at how it comes off. lol my dad took it off and i put it on while he wasnt there...plus he didnt notice how it came off anyways, he assumed it went how i put it on.
