Hello all , another 5.4 swap in progress!
I found a deal on a complete 04 navi motor and am swapping the 4.6 out of my 02 Expy this weekend.
The Navi motor has NO oil in it, my question is once I have swapped the engine , how do I get the oil pressure up when first cranking it without damaging anything ?
upgrade the injectors since your getting a custom tune anyway.
the DOHC motors can make gobs of torque
good luck on the install, I'll be lurking around as this swap interests me but sorry I know nothing about the modular oil pumps
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon) old albumshttp://www.f150online.com/galleries/....cfm?gnum=8805
I have a Procharger D1SC on the 4.6 thats going onto the 5.4 at 12lbs, just installed 60lb Siemens injectors and will be using a Vortech aftercooler from a 97 Cobra (fits perfect!) . The motor has not run in a while and I have it on an engine stand, so flipping it upside down and back again with the oil pan off (just put on a new 5.4 f-150 pan on) all the oil is out of the engine.
I see.
That's going to be one fun brick to drive once everything is said and done!
If you are filling the motor for the first time, fill the oil filter and put it on the motor, also, take the valve covers off and put oil on all the valves and cams etc. This way when you crank it over the head shouldnt be to dry and the motor will instantly suck up oil from the filter. Other then that you should be ok I'd believe.
Pulling the fuel pump fuse sounds like the way to go, thanks. When I pulled the Navi oil pan off, the motor was spotless inside. I saw it when it was still in the wrecked truck and according to Car-fax , that Navi only had 36k on it. The engine is just broken in. READY FOR BOOST
