Perplexing overcooling on 97 4.6
  #76
Old 12-22-2008, 02:46 PM
Usually no, unless you want to take off the fender. I mean most times on trucks the hoist will barely get high enough to clear the radiator and grill, and the fenders are usually another 2-3" higher then that.
It would be possible to have the hoist to the side of the truck, it would just be a bitch
  #77
Old 12-22-2008, 03:23 PM
Foe's Avatar
Foe
Foe is offline
OK thanks bud. didn't think so, but thought I'd ask...
Just got back from buying some ratcheting box end extended beam wrenches. Man these things are a dream when it comes to getting to the 13mm bolts around the tranny.
  #78
Old 12-22-2008, 04:12 PM
Foe's Avatar
Foe
Foe is offline
How many bellhousing bolts are there on the 4.6? <Never mind - I just found it - there are 6>
  #79
Old 12-27-2008, 12:10 PM
Foe's Avatar
Foe
Foe is offline
Motor mounts
Both of my manuals say to remove the insulator bolt from the motor mounts for engine removal. After looking at this I believe the entire engine mount pad (that bolts directly to the block) has to be removed.
Do I have to remove the entire engine mount pad or can I get by with just removing the single bolt that runs forward/aft?
  #80
Old 12-27-2008, 01:40 PM
Foe's Avatar
Foe
Foe is offline
Question Need a hoisting guru.....
I cannot get the engine to break loose.
ALL 6 tranny bolts and 4 converter nuts are off. Engine mount bolts are off. All hoses/wire harnesses/fuel/tranny lines are free. Exhaust manifold connections are unbolted. Tranny is supported with 5 ton ratchet strap attached to the frame (very tight).
I have a load leveler so I can shift the hoisting point.
Engine will begin to rise (in front), but it is binding at the tranny on the passenger side (I can see a gap in the driver side engine to bellhousing, but it's tight on the passenger side - no gap).
What confuses me is the flexplate/torque converter nuts. Are you supposed to drive the torque converter bolts (aft/rear) to disengage the flexplate/flywheel?
I haven't attempted this, but I can see where these bolts would cause a binding condition since I'm trying to left vertically and they're still sticking through the flywheel approximately 3/8".
What am I doing wrong?
  #81
Old 12-27-2008, 01:52 PM
masseyman's Avatar
Have you removed the starter?
  #82
Old 12-27-2008, 02:29 PM
Foe's Avatar
Foe
Foe is offline
Yep - forgot to mention that
  #83
Old 12-28-2008, 03:29 PM
Foe's Avatar
Foe
Foe is offline
It's out!
Finally got the engine out! Never thought an engine removal would make me happy.
I found the last hidden stud behind the bracket that holds the transmission dipstick....
In the process of swapping out components
Quick Reply: Perplexing overcooling on 97 4.6
