cylinder 2 not firing
Old 09-12-2008, 10:00 PM
Matts ford's Avatar
Originally Posted by macmillan
Cars and trucks are like precision watches. They need to be properly tuned at all times to get best performance. Cars and trucks today do not need tune-ups as often as was necessary 20 or 30 years ago. The recommended frequency for a tune-up is once every 25,000 miles, or as specified in your owner's manual. In some cases, it may be necessary to get a tune-up more frequently depending on the type of driving that you do. It is time for a tune-up whenever your engine is "knocking" or not firing on all cylinders
macmillan
Used Cars
he just did a tuneup.
Old 09-13-2008, 06:07 PM
glc is offline
Think it's time to take a look in there with a borescope?
Old 09-17-2008, 09:41 PM
GAZ1984's Avatar
yea thats an idea but the wet compression test should tell me if the bore or rings had a problem? sort of leaning towards electrical but i cant think of anything else apart from the coil but then it would be missing on all cylinders wouldnt it?
Quick Reply: cylinder 2 not firing
