F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #121
Old 07-13-2008, 05:22 PM
Vehicle: 1998 FORD F 150
Quote:
Originally Posted by Klitch View Post
yeah those were both plug n plan on my truck. do you have a wideband? im curious if you're just a hunch on the lean side.
I'm not sure what you guys are referring to as plug and play.
If you are not tuned for a 90mm and 42's, then it won't run, or shouldn't.
  #122
Old 07-13-2008, 05:50 PM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
i meant the wiring/connectors were plug n play. basically you connect them and go.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #123
Old 07-13-2008, 06:38 PM
I thought that was what you meant, but thought that clarification might not hurt.
I notice that your question about a wideband has not been answered. With boss's new set up, I would hope he has one.
  #124
Old 07-14-2008, 04:11 AM
even if he was borrowing one for the initial stages it would benefit him... but then i know the pocket book, it might bitch, mine did.
  #125
Old 07-14-2008, 02:06 PM
Vehicle: 2003 ford f150
i dont have one yet..i do know that i need one..i plan on getting it tuned on a dyno after about 500-1000 miles though..hopefully i will have one by then.. i do have a walbro 255 pump..if that makes a difference with not having bigger injectors..
[IMG][/IMG]
  #126
Old 07-14-2008, 02:29 PM
you have a fp gauge? even a mech one to just see what your fp is at idle and off idle. you have 20 - 15" vac?
  #127
Old 07-14-2008, 02:49 PM
i dont have a fuel pressure guage..but my vacuum is right at 20-21 at idle so i dont think i have any disconnected lines ne where..im hopin its just the timing and the bigger injectors..
[IMG][/IMG]
  #128
Old 07-15-2008, 07:23 PM
i just ordered my 42lb injectors and a 90mm maf..so hopefully it'll run better when i get them on in a few days
[IMG][/IMG]
  #129
Old 07-15-2008, 07:28 PM
Vehicle: 1998 Ford F150
I just dont see that helping... has to be tuning problems. at idle, its not needing more fuel... injectors only give as much fuel as needed, but maybe the tune for the 42's will be correct.
  #130
Old 07-15-2008, 07:36 PM
see thats the thing..it idles ok for the most part so i know that it has something to do with the tuning as well, but even if i get just 1/2 throttle or a little less i can feel it bog down..thats why im thinking that its the injectors and tuning (timing)
[IMG][/IMG]
  #131
Old 07-15-2008, 07:39 PM
built, when u asked to watch my timing on the programmer were you refering to spark advance? if so do you know what it should be about? or could you clarify what you mean...
[IMG][/IMG]
  #132
Old 07-16-2008, 04:32 AM
timing = spark advance on livelink. ive seen mine up around 30 at times.
  #133
Old 07-16-2008, 11:43 AM
Quote:
I agree. You can't expect to bolt on all of this and not have tuning issues. The pcm is going wtf. The O2's may keep it idling OK, but the open loop calibration can't be even close.
  #134
Old 07-16-2008, 12:38 PM
ive seen my up to about 28 i the predator..what should it be at at wot and at idle..
[IMG][/IMG]
  #135
Old 07-16-2008, 07:54 PM
at wot mine is between 12-15 depends on IAT2. around idle, i see 17ish
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
