F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #106
Old 07-10-2008, 03:45 PM
Vehicle: 2003 ford f150
alright guys i need help with one last problem...i am leaking antifreeze from the back of the motor..its only leaking on the passenger side rear when i put about 8 quarts of water in it..it comes out pretty fast..any ideas.
[IMG][/IMG]
  #107
Old 07-10-2008, 04:05 PM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
back of the motor? like a freeze plug?
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #108
Old 07-10-2008, 04:15 PM
no those are in there for sure..any other ideas on where it could be commin from...heater hoses seem fine..and its comming from the upper passenger side of the motor but not necessarily the heads
[IMG][/IMG]
  #109
Old 07-10-2008, 04:20 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Quote:
Engine off or running?
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
  #110
Old 07-10-2008, 04:34 PM
lol sounds like your heater core isnt hooked up
  #111
Old 07-10-2008, 05:04 PM
it leaks when its off and when it has about 8 quarts of fluid in it.so it is for sure comming from the top though and is the heater core the only other place it could be coming from..just tryin to gather up some ideas so i can drive this beast home today..thanks for all the help guys
[IMG][/IMG]
  #112
Old 07-10-2008, 05:17 PM
well if its not a freeze plug, and not coming from the head, the heater core has a barb from the intake manifold which sits about 4" high and should have a 90 in the top of it, and there is also a hard line that wraps around the back of the head that comes directly from the back side of the water pump.
  #113
Old 07-10-2008, 05:42 PM
Quote:
exactly..thanks
[IMG][/IMG]
  #114
Old 07-12-2008, 01:49 PM
alright guys i have plenty of pics to put up when i get some time truck has no leaks and runs good cam sounds sick...i do have a little problem i could use some help with though...the truck seems kinda boggy, could that be because im still runnin stock injectors yet? im gettin 42lbers but dont have them yet..thanks
[IMG][/IMG]
  #115
Old 07-12-2008, 04:24 PM
your running 19# injectors on a tune for 42?
  #116
Old 07-12-2008, 04:35 PM
no im still on the 19lb tune..thats why i think its just the fuel injectors,because it seems like everything else is fine..
are lightning fuel injectors a direct replacement and does there maf plug into my wiring without any modification...thanks
[IMG][/IMG]
  #117
Old 07-12-2008, 05:14 PM
L maf is plug n play, my 97 harness worked with the L injectors.
i think the injectors could be part of the problem only because your tune.
were they clean?
second thought after post, your not running the L maf right now with 19# inj right?
  #118
Old 07-12-2008, 07:46 PM
no i dont have either yet im gettin the maf and injectors in a package..they are both plug n play correct?..the injectors were only cleaned with mineral spirits so it wasn't the best..i think to prob is just not enough fuel though..so im babying my truck right now...the connections on the injectors on a lightning are the same as my truck correct?..thanks again..
[IMG][/IMG]
  #119
Old 07-13-2008, 04:05 AM
yeah those were both plug n plan on my truck. do you have a wideband? im curious if you're just a hunch on the lean side.
  #120
Old 07-13-2008, 01:50 PM
Vehicle: 1998 Ford F150
shouldnt be a fuel problem considering its bogging... data log it and see whats going on with your timing when it boggs
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
