In your example you will only trap faster than 110.8 if you rev higher. If you are running out of gear before reaching the end of the track you need to chose what to do to correct it. Shifting into 4 seems like a waste of time. It takes time to shift and you are not accelerating while shifting. What you need to figure out is how to be close to redline in 3rd gear at the end of the track. What rpm are you at when you finish?
Regards
Jean Marc Chartier
well i havent made it to the track just yet..workin on 1 lil issue on the tune..it pulls timing on a load and im just wanting to get that issue perfect b4 i go to the track...
i guess thats the only true way to find out is to see how close i am in the 1/4 in 3rd gear i just thought i would hit the limitor before i crossed the line..i agree with you JMC i DO NOT wanna hit OD at the track so i guess i gotta go there and try it as my truck sits now
Not trying to be a smart azz but there is a very simple solution.
TURN OD OFF! Then Raise your revlimiter!
Our trucks are not as different as you were saying(like JMC said,,trannies work the same)
As you know from running nitrous,you do NOT want to hit the rev limiter on the bottle!= bad news!
I have my revlimiter set to between 62&6400 rpm. And I'm not even close to that at the end of the 1/4.
I have a hard time watching the tack but I'm somewhere between 55 to 5800 going through the trap.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Phil
i think we are misunderstanding eachother..my OD will be off..i just simply didnt think i had enough rpm in 3rd to cross without over-reving...i just didnt think that my 3rd gear was long enough..as in i have to let off b4 the 1/4 not go into OD
You said your shift points are set a 5600 rpm.
What is your top speed rev limet set at?
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Find out what your rev limet is set at,,and if anything you might just have to adjust it. But otherwize you should be fine with the 4.10s for now anyway.
Now when you start going faster and faster like we all love to do.You might need to make a gear change.
Like if you start hitting 125,130mph,then you'll have to go with 3.73s or 3.55s.
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Another option might be to adjust your 1-2 and 2-3 shifts points. 100 rpms more for 1-2 and 200 rpms more for 2-3 would make 3rd taller so to speak. You do need to know how long your shifts actually take though, or you could hit the rev limiter at 6,200 from a commanded 5500 shift point
true, but my truck shifts very quickly within 200rpms of the set shift point..i have a troyer performance valve body and its shifts very quickly and firm..im gonna set my rev limit to 6200 and see if i can make it through the 1/4 with that without letting off
Let me know how that goes for you. I would like to hit up a 1/4 mile but want to make sure i can make a full pass before i make the drive. I have 4.10's also
well if it doesnt rain im going to the track this tuesday on my street tires...they are 29.7in diameter..so they are very close to the 30" m&h slicks...i hope i have enough gear
i got a dual inlet dual outlet dynamax ultra flow x muffler and it sounds awesome...
went to a portable dynojet at a show in st.louis..truck sat for 2 hrs and went up and put down 477hp..there was an L there that put down 594hp and a TT 03 cobra put down 750 on an unloaded dyno!!!
and i should have some new parts comming soon, i'd tell ya but figured you can wait lol...its 3 different parts...
