F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #76
Old 06-22-2008, 04:51 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
http://motors.shop.ebay.com/items/42...23Q20injectors
after shopping around and knowing it's a temporary part, I got a set of these:
http://cgi.ebay.com/ebaymotors/_Car-...3756.m20.l1116
  #77
Old 06-23-2008, 03:11 PM
Vehicle: 2003 ford f150
finally my block is done.. we will be re-assembling the motor tues & wed. since im off those days..hopfulley we can get it done by then and put up a video...
[IMG][/IMG]
  #78
Old 06-23-2008, 03:13 PM
Vehicle: 2005 Ford F150Lariat
  #79
Old 06-26-2008, 03:46 PM
Vehicle: 200? FORD
can't wait to hear the "new" engine running
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
  #80
Old 06-27-2008, 02:03 PM
yes sir. me too.. the piston rings were a pita they each had to be filed for nitrous over 150..so that obviously took some time..i should have it ready this saturday or early sunday..i cant wait
[IMG][/IMG]
  #81
Old 06-29-2008, 05:55 AM
Vehicle: 200? FORD
any progress? i didn't see any news pics
  #82
Old 07-03-2008, 05:07 AM
alright guys. we are almost done but is there a trick to bolting back up the ac pulley.we have spent hours on it and cant get it..we have to do that, put the fan and shroud back on and hook up the coolant lines and we are done...but we are having a huge problem with the ac pulley/unit to bolt back in..any tips...i have many pics i will upload as soon as its finished..
[IMG][/IMG]
  #83
Old 07-03-2008, 05:20 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
i laid my head under a-arm to crossmember bolt so i could see up and get dirt in my eyes, stuffed my right hand up by the tie rod and the left arm u found a rather straight shot with and alternated tightening bolts.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #84
Old 07-03-2008, 10:44 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Make sure that the belt is off of the pulley? I used a screwdriver, phillips head, pushed through the bolt hole of the compressor and the engine block to line up one of the holes. That acted as a handle and also kept the compressor sort of lined up. Pushing a bolt through the other end I only needed to pivot the compressor to line up the bolt hole at the other end as it was already lined up by the screwdriver.
Regards
Jean Marc Chartier
  #85
Old 07-05-2008, 08:52 PM
i dont have pics of the part that i am having trouble finding where it goes but ill try to explain it..it looks like a vacuum hose but has three different ends and its about a foot long...also does anyone have pics of what goes onto the opening of the passenger side valve cover..also there is a connection on top of the egr valve i think its a green connector..there is also a white one do any of you guys know where it goes ..ill try to post pics just dont have a camera right now...thanks
[IMG][/IMG]
  #86
Old 07-06-2008, 04:21 AM
i think that is a diagram on your front clip cover thinger? red should go to your fuel press regulator, green egr and white or whatever is left should hit the evap port.
  #87
Old 07-08-2008, 11:14 PM
hey im in need of some help.. the truck started fine and all the internals seem to be well but we had a major oil leak comming from the back of the motor by the tranny..i had a new rear main seal put in..could that be it..the oil is not coming from the dipstick area, filter, or drain plug and its all clean on top of the motor..please help asap...thanks
[IMG][/IMG]
  #88
Old 07-08-2008, 11:16 PM
Vehicle: 1998 Ford F150
someone didnt put the oil plugs back in the head....
  #89
Old 07-08-2008, 11:23 PM
Vehicle: 1998 FORD F 150
Quote:
That's an ugly thought. I have heard that it is impossible to get them in with the engine in the truck......anybody tried?
  #90
Old 07-08-2008, 11:31 PM
its not possible, you can get to them with the tranny out...... or maybe, just maybe, with the intake manifold off
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
