F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #766
Old 03-25-2009, 10:18 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
he has comp cams... 102600 I believe
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
  #767
Old 03-25-2009, 10:19 AM
Vehicle: 1998 Ford F150
Quote:
Originally Posted by Z7What View Post
The N/A and Lightnings have the same cams.
Wayne
He's got Comps from when he did his build up. Not factorys, or at least i think they are comps.
1998 F150 SuperCab Lariat 4x4 5.4
  #768
Old 03-25-2009, 10:20 AM
Dang it you beat me to it ^^^
  #769
Old 03-25-2009, 03:18 PM
Vehicle: 2003 ford f150
Quote:
correct....550/550 lift...
[IMG][/IMG]
  #770
Old 03-25-2009, 05:57 PM
Vehicle: 2003 Ford F-150
Send a message via AIM to Z7What
Since you are built and have a ported blower and your going to need a MAF, injectors and another tune i'd throw a 6# lower on it!
I was just thinking and have a questions or more of a statement.
EDIT:
I'd like to see how your tuner is tuning cause i have NEVER EVER heard of a 4# lower maxing out a MAF and 42#s. I have friends with 6# lower with 42# injectors with room left yes the MAF needs to be changed with the 6# lower but NEVER a 4# that i have ever seen.
I have a 4# lower and 90mm maf and have plenty room left with my maf and injectors.
Wayne
2003 F-150 FX4 Powered by 2003 Lightning Engine #2005
AFCO H/E With Fans, Killer Chiller, Ported Throttle Body, Ported Plenum,
Ported C&L Elbow, Metco Idlers, 4# Lower Pulley, Bosch 255LPH Fuel Pump, 90MM MAF,
K&N Filter,EGR Delete, L&S Oil Separator, NGK TR6, Flex-A-Lite EFans, 170* T-Stat
Sooned To Be Tuned By Total Performance Solutions
Best 1/4 14.569@ 90.84MPH
Best 60' 2.08
  #771
Old 03-25-2009, 06:18 PM
Vehicle: 200? FORD
I wonder if it's his fuel pump...
  #772
Old 03-25-2009, 06:46 PM
I believe he has a 255LPH which also should be fine for up to a 6# lower. The same guy i was talking about with the 6# lower and he is running a single 255LPH pump also without a problem so i dont know. He also has long tubes, and all the supporting mods for a 6# lower.
Im confused!
Wayne
  #773
Old 03-25-2009, 08:07 PM
Vehicle: 2003 Fast Screw
Ya think it could have something to do with his 10.2:1 compression pistons?
I think he'll make a lot of power with that compression,,Might not be able to run much timing on 93 octane,,,but put some C16 in there and look out!!!! He'll be running circles around all of us.
He is probably making a lot more power with a 4# pulley then most Ls would with a 6# pulley!
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #774
Old 03-25-2009, 08:25 PM
I think you are spinning the eaton to fast, i think you will be way happier with a 6# lower and maybe a killer chiller.
Wayne
I have a 6# lower with a magnum powers
  #775
Old 03-25-2009, 08:27 PM
Phil
your correct. I didnt even think about that. Im at 8.4/1, wish i woulda done 10/1...
  #776
Old 03-25-2009, 11:08 PM
Phil
Wow, didnt know he was running so much compression
Quote:
Had know clue you took the eaton off and went with a smaller lower
Wayne
  #777
Old 03-26-2009, 03:43 PM
EDIT:
Wayne
true, however, it seems to me im making more or equal hp to somoene who'd be running a 6# lower..its making way more power than i thought at only 6*of timing..the tuner said my injectors were close to being at its max duty cycle and figured i might as well get injectors with the maf to save me money for another tune..
[IMG][/IMG]
  #778
Old 03-26-2009, 05:03 PM
just a lil fyi the boost stays right around 11psi..i thought id be more but i guess not..
[IMG][/IMG]
  #779
Old 03-26-2009, 06:54 PM
Quote:
Do you have full exhaust? That might be why. Boost is only a measurement of back pressure/restriction, guess your flowing really good!
Wayne
  #780
Old 03-26-2009, 07:54 PM
he has long tubes no cats and 3" exhaust lol. that explains your 11psi... with that much power and that little boost, all i can say is wow
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
